Possible problems with a Pioneer Elite Pro-610hd crt-rptv. Any suggestions?
  • Jeremy77
    • 9
    I have a Pioneer Elite Pro-610hd hd-crt-rptv and recently I noticed horizontal lines going through the picture. The lines are the most defined any time the tv has a solid color or plain white background on the program material be it dvd or hdtv. It is hard to describe this in words, but it looks like a ghost image of faded out and somewhat thick (appear to be about 1/16 inch thick) horizontal lines "on top" of the picture. Kind of like looking through a "screen" but I only see horizontal lines. Right now it is not to bad, but you can see the lines. I never noticed this before and was wondering if anyone might know what the problem is? The tv is out of warranty (the tv is 5 years old) so no luck on warranty repairs.
    I was also wondering if it is worth having the Pro-610hd repaired or get another crt rptv of equal or better picture quality? If I end-up getting another crt rptv I would like to know what brands are recommend?
    Currently I am looking at the Mitsubishi 55" and the Hitachi 57" model# 57F510. I am not "stuck" on these brands, just looking for advice.
    Any information would be appreciated
    Jeremy
  • Sithlord
    • 285
    Sorry to hear about your problem. First I would call Pioneer and see what costs are involved in having a service tech come out and check it out. If the situation is bad, then I would recommend Hitachi as I own a 57" (Australian model most recent) and it's fantastic for the money. I was looking at Toshiba but they were just too expensive for the same size. Our RRPTVs here in Australia are limited in model availability unlike the US where Hitachi RPTV have HDMI now. DLP TV technology is becoming affordable now so you may want to look into that option as well. Anyway good luck with your enquires and good hunting.
      Twin Moderator Emeritus
      • 16706
      I've got a Hitachi and it's fantastic :T Mitsubishi's the other brand I'd recommend
      • Shane Martin
        • 2852
        Does it happen on all inputs? Likely it will need to be looked at. Having it looked at will run you anywhere from $100-$400 depending on what's up. I didn't see too many issues that ran much past that unless it was a CRT tube and I can't imagine that is the issue here. Now whether you want to spend that kind of cash on an existing set is only something you can answer.
        I will say that if you do decide to buy a new set, I'd look at the brands suggested Hitachi and Mits. I know that when I was buying Hitachis were alot more money and I didn't see the quality difference to pay the extra cash. A person I know of in Georgia said he saw a 65" 9" crt Mits for $2200ish delivered which is a deal and a half. Mits is the only manufacturer of CRT RPTV's left to go with 9" guns on its sets.
        I would almost recommend a Sony but I've heard of too many issues with them lately to suggest them. I didn't care for the picture when I compared it next to a Mits at the store.
        • Jeremy77
          • 9
          Shane Martin,
          yes it does happen on all the inputs that I am using. Component 1.hdtv 2.dvd. input 3 is s-video and I use the switching in my dc-1 for (dish, laser disk, and s-vhs).
          Thanks for the help
          Jeremy
          • Shane Martin
            • 2852
            Power Supply or solder joints are my 2 thoughts of what issues are causing it. Likely it will cost you a few hundred atleast.
            IMHO, given how good the Elite sets were, I don't think you'll improve the Picture at all unless you get a 9" crt Mits. The others would be a lateral or downgrade to me. Elites were considered the very best CRT.
            • Sonnie Parker
              Comments on my new Toshiba RPTV...
              by Sonnie Parker
              I finally got my new Toshiba 65HDX82 Widescreen RPTV set up. :yesnod:
              It was a long day as I had to work it by myself. Trying to get that styrofoam out from under that 280 pound set was not as easy as I thought it would be. :sos: Picking up one end with one hand (while on my old and...
              12 December 2002, 01:09 Thursday
            • Clive
              Home Theater Glossary
              by Clive
              G'day Members. As part of our efforts to assist new and seasoned members I am starting this thread, to be used as a quick reference guide.
              I am sure that there will be some missing from this original list so in that case I will ask that members can post the words and there meaning/explanations...
              11 July 2005, 22:38 Monday
              Me 'N Pioneer - Analog HD Inputs vs. Digital HD Signals
              by David Meek
              You've probably seen one or more of my comments about my year-old Pioneer Elite Pro 610 HD-ready RPTV. Yeah, I know. What can I say - I love this set. The only drawback this unit has is that the high-def signal inputs accept only an analog signal. With the studios and manufacturers working hard to have...
              17 July 2002, 08:01 Wednesday
            • Trevor Schell
              Liquid Crystal on Silicon (LCoS) FPTV (Hitachi)
              by Trevor Schell
              Hitachi CPSX5600W 1500 ANSI LUMEN 1365X1024 HDTV
              Using Hitachi''s advanced LCOS technology, the CP-SX5600W packs high resolution SXGA+ capability and outstanding image quality into a portable projector that competes head on for value with XGA models. Class leading video...
              03 October 2003, 23:43 Friday
            • rcchap
              Hitachi 51s715?
              by rcchap
              Looking at purchasing a Hitachi 51s715 for $1799. This seems like a reasonable price for this TV. They offered an extended warranty of 5 years including in home repairs etc for $400. I have never bought an extended warranty or a RPTV for that matter. Does anyone have any suggestions or opinions...
              22 September 2004, 15:18 Wednesday
