Throw distance for Z3 & AE700
  • Swampy
    • 10
    I'm in the process of doing my media room and I would like to use a shelf on the back wall rather than a ceiling mount. My room is 18'4" long. Using the throw distance calculator for each model on projectorcentral.com it appears that it a shelf at the back of the room will be suboptimal or won't work for the AE700 or the Z3. Does anyone have experience with either of these models at a throw distance of 17'? I'm concerned about screen size and brighness/contrast at that distance.
    Thanks in advance! :P
    • 16209
    You're going to be in a tough spot there if you want to use that long a throw distance- for quite some number of years (ever since the Sony 10HT, for example), digitals have usually been shipped with relatively short throw lens, so that a large picture can be obtained in a fairly small room- say, using table top or ceiling mount. Older projectors like the Sony 400Q had multiple lenses available- at considerable cost - its a big part of the cost of the projector. Some even used the standard 400Q lens on the 10HT- this could be done, and resulted in much longer throw distance.
    The AE700 has a much longer throw zoom range than most digitals- 2X, and can throw a 100" diagonal image anywhere between 10ft and 20ft- this is very flexible as these units go- how does that not fit into your parameters? Were you considering a larger screen than 100"? At what seating and viewing distance? If you're considering a screen size larger than 100" (say, 119"), you may want to evaluate first the viewing angle and possible SDE at that distance - personally, I don't think 1280X720 projectors hold up that well on that large a screen (BTDT). But, if you're siting well back from the screen, maybe it will be fine. If you have a chance to demo one before committing to your setup, I'd recommend that.
    If you're considering a smaller screen (a good move), then the throw issue will be a problem; 96 should be OK, but 18 ft will be too small with a smaller screen, in all likelihood.
    ~Jon
    • Swampy
      • 10
      Thanks for the feedback!
      My viewing Distances will be around 12' and 17', or 11' and 16' but could be moved closer for optimization. My screen size will be whatever is best for the configuration. I'm going to paint my wall for starters with a mix recommended by Andrew Pratt on this forum and I'll wait to paint it until I determine the best size for the projector. If I have to spring for a ceiling mount then so be it.
      With the Panasonic 700, is the zoom fixed at 1 or 2 or is it variable? If it's variable, I should be able to come up with a good size screen of around 100" diagonal shouldn't I?
      Thanks again! :T
        • 16209
        It's variable, continuously from 2:1, so you could easily support a typical 96" or 100" screen from the back of the room.
        • SZ99
          Shortest throw distance / Smallest image
          by SZ99
          I need to project an image that is about 3 inches wide (diag). Therefore, I need a projector that has a very short throw distance and that makes very small images (obviously I am not planning to use it as a regular projector). Also, the technology must be DLP. Does such a product exist or what is...
          17 February 2005, 09:55 Thursday
        • Rolyasm
          Do I have to move Projector to change screen size???
          by Rolyasm
          Let's say I had the Optoma HD81 and wanted a 110" diaganol screen. According to this site I would have to have the Optoma at 17.7'. If I had only 16' to the back wall, would I just have to use a different projector, or do most projectors also have function to adjust screen size without moving...
          10 November 2006, 19:13 Friday
        • Bent
          projector throw angle?
          by Bent
          Greetings,
          Although I currently have a Widescreen RPTV, I am trying to keep up with the fast-paced-ever-changing world of LCD and DLP projectors, one of the hang-ups I have with them is you can get a short throw pj (Panasonic AE series), or a long throw (Sony VPL-400Q, I know it's long in the...
          05 October 2003, 22:10 Sunday
        • M.Roberts8
          Need screen suggestions
          by M.Roberts8
          I am almost ready to order my projector. Was planning on the panny 900 but now the new ones are out and I am leaning toward the sanyo Z5 since I can get it for 200.00 more(after rebate) than the 900.
          For screens I am looking at a manual pull-down right now but I have some concerns about the "waves"...
          12 November 2006, 16:58 Sunday
        • Jeremy77
          New to front projection. Need help/advice
          by Jeremy77
          Ok first let me apologize up-front for my lack of knowledge on front projectors.
          What little video knowledge I have is on rptv. I am trying to find out if it is even feasible for me to get a projector. The way my room is set up my viewing distance form the screen would be limited to 11-12 feet...
          06 May 2005, 23:48 Friday
