Converting DVI to Component or RBGHV
  • Onabudget
    I just bought a new DVD player with the HDMI outputs, I bought it cause I could have sworn my RP HDTV had a DVI input. So I got the DVD player and the HDMI to DVI cable to hook it up with, when I got home I realized my TV did not have the correct inputs. However it does have a dedicated RGBHV/Component input for Digital signals that can display 720p/1080i. So my question is, is there a way to conver the signal from HDMI to DVI to RGBHV and still display the 720p/1080i resolutions? If so, where can I find the DVI to component or RGBHV coverter? Thanks in advance for your help.
  • june
    DVI or Component??
    by june
    Hello All,
    I want a second unit for the bedroom (Panny BD30). It will be hooked up to a Sony 34XBR910 1080i TV. This set has component & DVI inputs. For the best picture, which is the best way to hook up the BD player:
    HDMI TO DVI
    or
    COMPONENT
    20 March 2008, 13:09 Thursday
  • boostdfd3s
    Converting DVI-I to Component?
    by boostdfd3s
    hey every1,
    i recently built a HTPC with a radeon 9200SE for a vid card. Was banking on my 22" samsung LCD having VGA and DVI inputs but sadly that wasnt the case when i brought it home Also found out the hard way that you cannot have two High def channels in PIP because of the single...
    28 December 2004, 00:58 Tuesday
  • DLA
    HDMI>DVI Gender Benders
    by DLA
    My Mitsubishi HDTV Model # WS-55315 has only a DVI input not a HDMI...my cable company has issued new boxes that have only HDMI whereas the current has only DVI which I use. I plug in my DVI cable and it reads as the "Monolink" though I do have a DTV input (no used). so here are my questions....
    23 November 2005, 18:05 Wednesday
  • RebelMan
    Which connection is right, DVI/HDMI or Component Video?
    by RebelMan
    The video outputs from my satellite dish receiver support either DVI or component video. When using the DVI side the colors appear a bit washed out. When using the component side the colors appear a bit over saturated. The detail seems to be the same in each case, although the component side looks...
    14 October 2005, 12:45 Friday
  • draganm
    Marquee CRT projector and DVI input card
    by draganm
    A few people have inquired on this board in the past about being able to input a DVI signal into their CRT projector. For about a year now, a guy named Moome in Hong Kong has been manufacturing cards that plug directly into the electrohome Marquee, Sony, Barco, and NEC CRT projectors. The card accpets...
    01 July 2006, 12:20 Saturday
