How To: Export Impulse Response from REW for use in VituixCAD
  • How To: Export Impulse Response from REW for use in VituixCAD (prior to 2.0.98.6)
    Update: Since VituixCAD 2.0.98.6, exporting IR using windowing as described here is no longer required. the impulse response can be exported directly, make sure to uncheck "normalize" on export. VituixCAD will automatically set "skip samples" to 1m (2.907ms) prior to the start time of the exported impulse response to maintain correct timing on import.
    REW can export the measured impulse response directly as MLSSA formatted text file, which can be used within the VituixCAD IR -> FR tool, however the way REW exports this data is a bit weird. By default, it provides 1 second of data prior to the peak of the impulse, which is not very useful for retaining the timing information, t=0 on the impulse response chart. One way around this is to apply windowing to the impulse response file prior to export.
    The following procedure will erase all data prior to t=0 in the measurement, so make sure that the recorded impulse occurs after t=0 for this process. The measurement guide for REW for VituixCAD mentions to apply a timing offset when measuring, so the impulse occurs at t=0. This is due to REW's odd way of processing phase, which uses t=0 as the timing reference for phase, rather than the window reference time location. Applying the timing offset removes the excess phase from the measurement for more readable phase information.
    For this process I would suggest not using a timing offset, in which case t=0 will be the loopback reference time, and the impulse will occur a few ms after t=0.
    To export impulse response from REW with timing information included, set the IR window to 0ms (t=0), left window to 0ms, and set the right window to 1000ms to capture the entire measurement data. This will ensure that the first sample in the exported data is t=0, and the exported data is effectively not windowed. Note that if the impulse data occurs prior to t=0, like in a single channel measurement where impulse peak is at t=0, the window reference time should be decreased to a negative value to capture the impulse data. I would suggest 2ms prior to the impulse.
    Click image for larger version  Name:	dataurl478962.png Views:	0 Size:	28.5 KB ID:	927358
    ​Export the impulse response as text, un-check “normalize samples to peak value” to maintain the measured amplitude information, and check “Apply IR Window before Export” to export only the windowed information.
    Click image for larger version  Name:	dataurl514907.png Views:	0 Size:	42.1 KB ID:	927359
    That's it, you can now process the impulse responses in VituixCAD following the guide for ARTA, starting at page 7 "Exporting far field responses​".
    https://kimmosaunisto.net/Software/V...ement_ARTA.pdf
    • kimmosto
      kimmosto commented
      Editing a comment
      MLSSA impulse response as text file starts with:
      0
      0.020833
      262144
      3.276819E-07
      2.736350E-07
      1st line is just 0
      2nd line is sampling interval in ms
      3rd line is length of data
      Data starts at line 4
      So REW's text export is not MLSSA format.
      One possible solution is that I modify text file reader in Convert IR to detect sample rate, start time and length from REW text format, and skip most of empty samples (with negative time) automatically. After that process would be closer to ARTA and CLIO.
    • Reet
      Reet commented
      Editing a comment
      Hi kimmo,
      Sorry, I’m not well versed in MLSSA file formatting. The problem observed if I export the impulse from REW directly without windowing is that the peak of the impulse occurs always at 1 second mark, so timing information of t=0 is lost in the export process. Applying the window allows for sample 1 of saved impulse file to be at t=0.
    • Reet
      Reet commented
      Editing a comment
      Oh I see what you mean now, Kimmo. The exported mipulse from REW does include timing reference, as one of the first lines in the text file, however is rejected by VituixCAD because it's not proper MLSSA format.
    Posting comments is disabled.
Latest Articles
  • How to: Measure with REW for Room EQ
    by Reet
    REW is a powerful tool, as is EQ, but getting it right can be challenging. The first step to achieving a good EQ profile for your space is to take in-room measurements. This document will detail an easy method to achieve quick and reliable results.
    For room EQ, a single measurement at your listening location will not produce a good depiction of the overall room response. An average of many measurements around the listening area should be completed to create a room response for equalization...
    12 April 2023, 11:42 Wednesday
  • Minimum Phase and Accurate Crossover Simulation
    by Reet
    Minimum phase for a speaker can be described of the phase of the frequency response of the speaker at it’s acoustic centre, or the phase without any excess phase or “time of flight” included. It can be calculated from the speaker’s frequency response using Hilbert-bode transform, or HBT. When comparing multiple minimum phase responses, we can say that the responses occur at the same point in space, ie. there is no physical distance between them. When measuring speakers and processing the...
    26 December 2022, 15:27 Monday
  • How To: VituixCAD Extended Impedance Model For Any Driver
    by Reet
    26 December 2022, 15:07 Monday
  • How To: Measuring impedance and T/S with ARTA/LIMP
    by Reet
    With a simple jig, loudspeaker impedance and T/S parameters can be easily measured with LIMP. The same jig may also be used to measure component value for resistors, capacitors, and inductors, as well as measure transfer functions of passive and active filters.
    The setup is quite simple, the following diagram is taken from the LIMP manual:
    https://artalabs.hr/download/LIMP-user-manual.pdf
    Measurement Jig
    This instruction is following what...
    26 December 2022, 15:02 Monday
  • How To: Mirror EQ with VituixCAD
    by Reet
    With VituixCAD, we have the ability to provide a mirror EQ function, that can then be passed to APO EQ for active processing. This allows for a speaker's frequency response to be fully compensated for without requiring many bands of parametric EQ.
    ​VituixCAD Process
    Connect each driver and EQ blocks in the crossover section as shown. Ensure that the active peak/notch filters are “shorted” so that only the G(f) block is directly connected to the driver. Three PEQ blocks are show,...
    26 December 2022, 13:26 Monday
  • How To: Filter Simulation with VituixCAD and EQ APO
    by Reet
    With meticulous passive filter design, it may be beneficial to hear the result before spending money on crossover parts and putting in the time to assemble the crossover. Fortunately, with VituixCAD and EQ APO and filter can be simulated digitally. This process can simulate multiple drivers simultaneously, one driver for each output on a soundcard, for example a 7.1 soundcard could simulate a stereo 3 way system utilizing 6 channels.
    Note that an emulated passive filter will reproduce...
    26 December 2022, 12:55 Monday
