I just got a Rotel RMB-1075 and a Marantz SR4500 as a temporary pre/pro. I will need to save up for the RSP-1066 or 1068 first.
I've hooked all my speakers to the 1075 so the receiver only acts as a pre/pro. I've noticed that even with no speakers attached to the receiver, it gets pretty warm. A lot warmer than the receiver WITH speakers connected. And definitely a lot warmer than the 1075.
Will I damage my receiver's built-in amp this way? I'm thinking that maybe the receiver's amps are driving harder since it sees a load with infinite ohms (no speakers, no flow).
So I'm thinking, maybe I should connect my surrounds to the Marantz just so that it doesn't complain of driving air!
Any suggestions or insights?
Maybe I could get a skilled electronics guy to open up the receiver and temporarily disable the amps. That might reduce heat, reduce wear-and-tear, reduce electric consumption, and maybe even improve the quality of the pre-pro.
