Rotel rsp-1068 buzzing sound...Heelp pleeease
  • Micke.H
    • 34
    Hi .
    I just bought a Rotel rsp-1068 and iam disturbed by the buzz/noise the 1068 does at low volyme the noise is quite loud ..too loud for me and i wounder if anyone else is having the same problem??
    I have tryed to change powercord and diffrent settings "bypass "and all but the noise is still there :cry: PLEASE HEELP ME.
    By the way, im from Sweden so my English is so so.Thanks anyway.
  • Azeke
    • Mar 2003
    • 2123
    Welcome.
    Quick thoughts.
    1) If you have cable, disconnect to see if that stops the noise (this seems to solve at least 90% of issues).
    2) If not you will have to disconnect your equipment, and reconnect each component (including amps), until you find the culprit.
    Good Luck.
    Azeke
      Twin Moderator Emeritus
      • 16706
      Yup, sounds like an another ground loop hum. Likely Cable or satellite feed as Azeke pointed out. If not follow his instructions and unplug everything, plugging back one thing at a time to narrow it down.
      • Micke.H
        • 34
        oki. i will try thath but i have no cabel and it did not buzz with rotel rsv-976..
        but i will report if it helped..
        thanks for now .
        • Micke.H
          • 34
          Ohh Yeaahh no mr buzz im my speakers
          It was the osd cable to my Sony tv ..there you go..
          problem solved ,thanks for the input.
          And the soundquality in 2 channel with bypass is unbeliveble
            • 16706
            Glad you found it and are enjoying :T Do you have satellite? My guess is your TV is spreading the ground loop from the satellite hook up via that monitor cable.
            • AngelEyes
              HTPC and Rotel RSP1068 Interference / Noise
              by AngelEyes
              Hey chaps, I hope you can help.
              I finally switched from digital coaxial to 7.1 analogue connections between my HTPC and Processor to take advantage of the new sound formats.
              Unfortunately the upgrade has introduced a nasty buzzing sound through the speakers. It does not...
              24 April 2007, 05:21 Tuesday
            • xspale
              Rotel 1065 Buzzing Problem
              by xspale
              Hi Everyone,
              I am new to Rotel and this forum. Before few weeks I purchased Rotel 1065 A/V Receiver from 2002.
              If I am close to speakers I can hear silent buzzing sound from left speaker. I have tried to disconnect everything and switch to fm tuner but buzzing is still there....
              07 January 2009, 04:14 Wednesday
            • wywong
              RSP1068 problem
              by wywong
              Hi, my 4 yrs old rotel rsp1068/rmb1075 suddenly drop the right front channel yesterday. I switch the RSP1068 pre-out right and left front connection and the problem will move from right to left. So it definitely mean it is not a cable or rmb1075 amp issue. I try power cycle, unplug the power and wait,...
              20 December 2009, 11:31 Sunday
            • torgelow2005
              high frequency noise / hiss, RSP1068
              by torgelow2005
              I'm using the RSO 1068 + RMB 1075 and I'm not satisfied with the noise behavior!
              I'm not talking about white or pink noise from the power amp but about a high frequency signal (kHz range, like
              tinnitus) mainly from the rear speaker.
              I only hear this noise when...
              02 September 2005, 13:14 Friday
            • wettou
              Using white noise to aim and adjust speakers
              by wettou
              Using white noise to aim and adjust speakers AIMING and "LEARNING" SPEAKERS Here is a method for "aiming" ...
              25 July 2010, 16:28 Sunday
