Problem with RSX-1067
  • Jraducha
    • 51
    Hello all. Im new to your fourms. I have been reading these fourms for some time now and just signed up to post.
    I have just put together my first home theater and I am having some problems at this time. I just purchased about a week ago a RSX-1067, Marantz 6400 DVD player and dynaudio speakers. I could only afford the Audience series beacuse I bought the Dynaudio speakers for my car too... but hey at least it is a start. (im only 20) And dont laugh but I have it set up in my bedroom that is 14ft by 11ft or so...
    Well on to my problem....
    I got the marantz player because it plays SACDS and DVD-A but I dont hear my SACDS in 5.1. Am I doing something wrong. I have it hooked up through "multi-input" I damn cable I needed to hook it up cost me an arm and leg. The cd I was listening to was Dark Side of The Moon and a few others. How sound I set up the rotel to play them in 5.1? I even hit the multi inut button but nothing????
    Thanks all...
  • redbears
    • 9
    Not sure on the Rotel, but is the DVD player outputting SACD/DVDA in 5.1? Reason I ask is some DVD players with 5.1 out for DVDA/SACD may default to a PCM downmix out of the box, until changed.
    If you can check the settings of the DVD player too! I am sure others here may help with the Rotel. I haven't hooked my SACD player up yet, but can't wait as that CD sounds great, and should sound even better with the new gear.
      Twin Moderator Emeritus
      • 16706
      Likely the player hasn't been set up properly. Read the players manual and make sure you set up all the options for DVD-A/SACD in the player and then make sure the Rotel is on the Multi input.
      • Azeke
        • Mar 2003
        • 2123
        Yes, I concur, sounds like an improper setup on the DVD player. Check the manual as suggested, esp., the trouble-shooting section.
        Azeke
        • Jraducha
          • 51
          thanks all...my analog was set up in 2.0..not 5.1 it works now!
          • Azeke
            • Mar 2003
            • 2123
            That's actually what happen to me when I intially hooked up my Pioneer 59 in multi-channel mode. Boy, my memory is really getting bad :roll: . Glad you figured things out :T.
            Azeke
            • Mike Hayes
              DVDA/SACD Connections to 1066
              by Mike Hayes
              I am considering purchasing a Pioneer 563A ($180) universal player to replace my Toshiba SD5700. I am currently using just the digital connection (not using the 5 analog cables for DVDA). This will be my first experience with DVDA/SACD in conjunction with my 1066 so please bear with me.
              03 August 2003, 09:53 Sunday
            • rick c
              Integrated amp w/dvda/sacd player
              by rick c
              I'm getting an int. amp probably one of the rotel's and was also planning on using a universal player to utilize my dvda/sacd collection.My question is i'm not sure if an integrated can be used w/ a universal.Also there would not be a display so would this be a problem in regards to the dvda/sacd player.This...
              05 November 2005, 23:50 Saturday
            • rick c
              ? for rsx1056 owners with dvda/sacd players.
              by rick c
              Those of you who have the rsx1056 with a dvd-a/sacd player how did you do the setup in the rsx1056.I understand that settings are done thru the dvda/sacd player but how about the receiver.I was looking at my receiver last nite and i beleive you need to go in the multi setup options but didnt see real...
              29 July 2005, 18:48 Friday
            • rick c
              rsx1056 owners w Dvda/Sacd and tosh. hd-a1?
              by rick c
              Those that have the tosh.HD-a1 how do you have it connected for audio.Digital or analog.Reason i ask is i have a denon dvda/sacd connected to my rotel so the analog is used up.The tosh i'll be getting next week.Undecided on should i just connect the tosh digital or am i going to have to get a switcher(which...
              03 November 2006, 13:06 Friday
            • rick c
              Got sony kdl-40s2000 bravia/dvd player ?
              by rick c
              I haven't been here in a while so i havent kept up with everything.Anyhow i just got the 40s2000 last week and am presently using denon dv2200 player via component since i also use my rotel rsx1056.Would an upconversion player be benificial to me.Would i notice a big difference in pq.I can always just...
              03 June 2006, 11:14 Saturday
