RDV-1050 problems w/DVD-A
  • ssavoy23
    • 12
    I don't have a clue as to why this piece is not decoding DVD-Audio disc. I've gone thru all of the prompts on the menu screen and I have it connected to the RSP-1066 and the only reading i'm getting is 48khz/8.9-bps...it doesn't even prompt me on the menu screen to select advanced resolution surround or stereo as an option; the only option that's given is the 5.1ch. or 2ch. stereo. Confusing enough is that the blue light is lit indicating that a DVD-A has been inserted but the sound options are not there. :twisted: Can someone please help me with this before I take this shite back?
  • aarsoe
    • 795
    Ssavoy
    This may be a dumb question, but how is the player connected? Sounds like you only use a digital cable - and not analogue as required.
    • ssavoy23
      • 12
      i do have the analog input connected as well...i'm also pressing the multi-input button on the rsp-1066 and nothing has worked; i'm trying to call someone at the local store about this very problem.
        Twin Moderator Emeritus
        • 16706
        Have you gone in to the menu of the player and properly set up the DVD-A options?
        • rick c
          rsx1056 owners w Dvda/Sacd and tosh. hd-a1?
          by rick c
          Those that have the tosh.HD-a1 how do you have it connected for audio.Digital or analog.Reason i ask is i have a denon dvda/sacd connected to my rotel so the analog is used up.The tosh i'll be getting next week.Undecided on should i just connect the tosh digital or am i going to have to get a switcher(which...
          03 November 2006, 13:06 Friday
        • rick c
          Marantz 6400/6500 or rotel rdv1050?
          by rick c
          I have been thinking of replacing my panny rp56 with a dvda/sacd player.I have a few dvda disks now.Also thinking of sacd.My question is the selection of which player for PQ as well as Audio.Between the marantz and the rotel which would be the better unit.I realize the rotel is only dvda and more expensive.Is...
          17 February 2005, 09:22 Thursday
        • miagi
          RDV1050 and problem with "spikes" on the 220v
          by miagi
          I´m having a VERY annoing problem using the RDV1050 DVD. -Whenever I (or my neighbour for that matter) switch the light on/off in my/his apartment (or my refrigiator turns on/off), the sound dissapear shortly, as if the RDV1050 loses sync (Via coax) to the RSP1068... it does not affect the picture...
          22 June 2004, 08:42 Tuesday
        • metallo
          Howto connect RSP1068/RDV1050?
          by metallo
          A new guy in town...
          Ive just bought a set of Rotel products (had Onkyo and Sony before)
          Rotel RSP-1068
          Rotel RDV-1050
          (Rotel RMB-1075)
          I have connected the dvd and pre-pro with 1 digital rca and 6 analog rca (DVD-audio).
          Video 1 shall...
          16 September 2004, 04:52 Thursday
        • Mike Hayes
          DVDA/SACD Connections to 1066
          by Mike Hayes
          I am considering purchasing a Pioneer 563A ($180) universal player to replace my Toshiba SD5700. I am currently using just the digital connection (not using the 5 analog cables for DVDA). This will be my first experience with DVDA/SACD in conjunction with my 1066 so please bear with me.
          03 August 2003, 09:53 Sunday
