Help with 1098 and SACD hook up
  • auburnu008
    • 5
    Hello everyone, Just wanted to say that I love this fourm and love Rotel! Today I got my 1098 and also got a new dvd player. ( a 400 disc Sony SACD and DVD player) Well I am confused as to how to hook it up to my rotel to allow me to use it as a DVD player and a SACD player. Any help would be greatly appreciated. So far I LOVE the unit and can't wait to listen to Pink Floyd SACD Dard Side of the Moon. Thanks again guys.
    Ryan
    Twin Moderator Emeritus
    • 16706
    You should connect either a digital coax or digital optical cable to the 1098 for Dolby Digital DTS (personally I like digital coax). Then you will also have to connect 6 (5.1 = L/C/R/SL/SR/Sub) analog cables to the multi-input of the 1098 as you can only listen to SACD (and DVD-A) through analog outputs from your player to the 1098. The one player will basically be treated like two devices by the 1098. For more information on the setup options on your player for SACD, refer to it's manual
    • theMaximus
      • 179
      I know getting 6 analog RCA cables can get very expensive, but that is the only option you have in order to listen to SACD or DVD-Audio. I would advise you not to mix different interconnects if you can avoid it. Check out the high quality interconnects offered by CAT CABLE. Many people have been raving about the silver digital and analog interconnects made by CAT CABLE.
      Victory Shall Be Mine!!! :heh:
      • chinets
        Kevin D and Kevin P question!! SACD on Rotel 1098 Via Digital??
        by chinets
        This is a typical Kevin D and Kevin P type of question as they are great at answering these type of questions. :T
        If I play an SACD in a sony DVD palyer and the light goes on the SONY and states that I am transmitting SACD signal ,and it is connected to a Rotel Pre/Pro 1098 In Digital optical...
        31 May 2006, 05:29 Wednesday
      • Blindamood
        Marantz SA-KI Pearl SACD/CD Player
        by Blindamood
        Has anyone else seen this new SACD player from the Marantz Reference line?
        Marantz SA-KI-PEARL
        I was on their site one day, and noticed this and its matching integrated amp (the PM-KI Pearl), and LOVE the looks of this thing. I've always thought the SA-15 was a great...
        04 June 2009, 10:20 Thursday
      • misterdoggy
        krell sacd/cd player would a c1 recognize signals
        by misterdoggy
        If you had a sacd/cd player like the krell, would the connections have to be 5.1 interconnects rca in or could it be digital.
        And if it was digital would the C1 switch automatically for SACD or would you have to select 7.1 to play it.
        Lastly, with a quality DAC like the...
        07 August 2005, 14:07 Sunday
      • Frank T.
        Rotel RSP-1098 Wish List 1.1 (Interfaces)
        by Frank T.
        I'm a home theatre dealer from Germany and have just received the new heart of my A/v demo system - the RSP-1098 - this Saturday.
        Kudos to Geoff Costello for all the time, sweat and effort on behalf of the RSP-1098. Constructive proposals like his are extremely commendable!
        26 October 2003, 17:21 Sunday
      • Mike Hayes
        DVDA/SACD Connections to 1066
        by Mike Hayes
        I am considering purchasing a Pioneer 563A ($180) universal player to replace my Toshiba SD5700. I am currently using just the digital connection (not using the 5 analog cables for DVDA). This will be my first experience with DVDA/SACD in conjunction with my 1066 so please bear with me.
        03 August 2003, 09:53 Sunday
