1066 analog input signal path?
  • Chris3G
    • Sep 2002
    • 30
    did a search and saw that this question was asked before, but never really answered. Does a signal going to the 1066 analog inputs (not the multi-channel inputs) remain pure analog all the way though, or is it re-digitized by the processor, as is the case with many HT receivers?
    Basically, can you run a 2-channel SACD signal through the analog cd inputs and have it played unaltered, or will it need to go though the 5.1 inputs?
  • Bruce
    • 156
    This question is rather complicated and it has a number of parts;
    1) Any analog input to the 1066 automatically gets the L&R inputs copied and re-digitized, always.
    2) The user then selects one of two methods for ouput: the original analog input signal (typically called analog bypass) or a digitzed signal with or without additional DSP (like DPL-II) processing.
    3) The problem arises with this copied digitized signal (item #1 above). It is always passed thru a digital low-pass crossover. It is then converted to analog with the DAC and sent to the sub output channel when sub=Yes or sub=Max (unless sub=no).
    If the global speaker setting is set to sub=no, output won't reach the sub, otherwise it will. The new software upgrades to the 1066 don't appear to change this, but do offer other options to minimize this copied bass output.
    Bruce
    ____________________________________________
    Bruce
    • wng
      • Dec 2002
      • 102
      Had thought about this too.
      Bruce, repeating for the sake of being sure, it seems, then, that we listen to the original analog signal only when the main speakers are set as Large and the sub is set as No. If the main speakers are set as Small, the sub setting automatically goes to Yes. In this configuration, is the output from the mains still the original analog signal while the bass from the subwoofer is a copied and re-DAC'ed signal? Is this correct?
      This dovetails into the Sub=Yes = Sub=Max "defect".
      Let's say you are in a surround format like DTS, and your fronts are set as Large, other speakers are set as Small, and sub is set as Yes, bass below the personally set crossover will be routed from the "small" speakers. If the sub is set as Max, bass below the crossover from ALL speakers is routed, hence bass doubling.
      But let's go with the sub set as Yes. Let's say you switch to stereo format, if the fronts remain as Large (full-range play) and the sub is set as Yes -- remember, no other speakers (i.e., center and surrounds) are involved now -- isn't this configuration IN PRINCIPLE (full-range mains and an activated sub) telling the 1066 to double the bass below the crossover with the subwoofer, making it in essence the same configuration as the Sub=Max configuration?
      • Chris3G
        • Sep 2002
        • 30
        ok i think i get it. so you CAN run a stereo SACD signal to the cd inputs, and get unaltered reproduction through the main speakers, while the sub will be playing a re-digitized copy of any information below the crossover setting. the main speakers will be playing full range despite the large/small setting.
        the same goes for the multi-channel inputs, with the only difference being that the crossover to the subwoofer is not adjustable.
        Is this correct or did i go wrong somewhere?
        • Mike Hayes
          DVDA/SACD Connections to 1066
          by Mike Hayes
          I am considering purchasing a Pioneer 563A ($180) universal player to replace my Toshiba SD5700. I am currently using just the digital connection (not using the 5 analog cables for DVDA). This will be my first experience with DVDA/SACD in conjunction with my 1066 so please bear with me.
          03 August 2003, 09:53 Sunday
        • Lonewolf
          Questions for RSP 1066 - 2CH Stereo and Cables
          by Lonewolf
          Hi all
          After doing a search and reading alot of threads on this forum, i fear i may have either learnt alot or confused myself more than ever.
          I have got a RSP 1066 (you figured that) and had some queries on how to get optimum sound out of it for 2 channel stereo from...
          05 August 2004, 00:18 Thursday
        • Drifterguy
          Rsp-1066 Bm
          by Drifterguy
          Well, I was finally able to put together a nice audio/HT system recently, and I stumbled upon this great forum. The info here is great!
          I do have a question about the RSP-1066's BM. I know that in stereo mode, the sub crossover setting does not apply a high-pass filter to the main speakers,...
          03 November 2004, 13:54 Wednesday
          1066 and DVD-A
          by aud19
          I'm having a small problem with the 1066 and my Denon 1600 when using the analog 5.1 ins for DVD-A. It seems to be defaulting Dolby Pro Logic II. How do I get it to just play the straight analog signal as is? I've resorted to hiting the 2-channel button on the front which I think is working but not...
          03 November 2003, 12:53 Monday
        • Martinf
          No true analog bypass on RSP-1066???
          by Martinf
          Prior to committing to a multi-channel pre-amp (RSP-1066), I’ve been studying the specifications and user manuals for both the Rotel RSP-1066 and very new RSP-1098.
          1. Some observations from RSP-1098 manual:-
          (a) On page 13 in the RSP-1098 manual it has an explicit...
          19 October 2003, 07:33 Sunday
