Rotel RC1590 Need BluRay Player Help
  • jesswin29
    • Sep 2015
    New here and thank you for your help.
    I bought an RC-1590 and an RB1582 MKII to power two B&W CM10 S2 speakers. I'll be using this setup for records, digital music and movies.
    I need help finding a Blu-Ray player to match my components. What options do I have to get awesome audio out of the player and into the 1590?
    Would a Pioneer Elite BDP-85FD be a good option?
    My understanding is that the RC-1590 has an in-built 32bit 768KHz Digital to Analogue Converter (DAC). Given Rotel's reputation for audio excellence this DAC should provide you with a very nice sound. If this is correct (I haven't heard it) it means you should be able to use a budget Blu-ray player and connect either the coaxial or optical output of that player into the coaxial or optical input of your RC-1590 and get good results. In the unlikely event that this combination doesn't sound good then you might consider buying something like an OPPO BDP-105D Blu-ray player and connecting the analogue stereo output of that player into your RC-1590 using either the RCA connectors or the XLR balanced connectors (XLR is preferred). The audio section of the BDP-105D is very good (I have heard it).
    So, in summary, you would be choosing between the audio section of your RC-1590 or your Blu-ray player. Only you can decide which sounds better. However, if I had recently bought an RC-1590 I'd be trying that option first before buying an expensive Blu-ray player.
    • BKSinAZ
      Connect bluray player question. Need Help please.
      by BKSinAZ
      I am wondering if from my blu-ray player, connect the HDMI directly to the television..... or thru the receiver that I am ONLY using as a preamp then out from the receiver to the television?
      My setup is Rotel RMB 1095 Amp, Pioneer Elite SC-37 as a preamp only, pioneer elite fd-23 bluray...
      15 July 2019, 20:08 Monday
    • ClosetSciFiGeek
      Which BluRay Player with Outlaw 990 Preamp?
      by ClosetSciFiGeek
      Just bought an Outlaw 990 Preamp. It does NOT decode the two latest codecs. I am going to use the 7.1 Analog Ouputs on a BluRay player. Which player would be best for this. My current player only has 5.1 outputs.
      09 May 2010, 15:37 Sunday
    • maseline_98
      CDs through bluray player
      by maseline_98
      I don't often do it, but I through my new Joss Stone CD into my bluray player(BD-55K) and gave it a listen. In my opinion, it sounded like crap. What's the deal with that? I don't often listen to much music in my living room and couldn't understand why it sounded so bad. I through it into my 360 and...
      03 January 2011, 11:55 Monday
      Bluray Audio Format Confusion
      by Johnloudb
      Okay, all these different audio formats have always confused me. On the back of this Jeff Beck Bluray disc "Live at Ronnie Scotts" it lists the audio format as LPCM stereo, Dolby Digital 5.1, DTS HD Master Audio.
      LPCM (Lossless Pulse Code Modulation) Stereo, is...
      17 April 2009, 18:33 Friday
    • sirbogey
      best upconverting DVD player
      by sirbogey
      I'm looking for a decent upconverting player to replace my RDV-1060. Can be a bluray player, but doesnt have to. I don't own one single bluray DVD yet :P . I do own a huge DVD collection though, so I want the best upconverting 1080p 24fps player there is, max $700. thanks....
      30 June 2009, 08:37 Tuesday
