RB1080 strange sound after shutdown
  • Jj157
    • May 2015
    I have the RB1080 that makes a strange sound a couple of seconds after shutdown.
    It sounds like a high frequency whistle and is no longer then a second. It comes through the speakers. It is like pfffieeewwwt
    Hope someone knows the problem or can give me some tips ;x(
  • madmac
    • Aug 2010
    • 3122
    Well........Rotel's are known for their strange (or shall I say different from other brands) sounds at start up and shutdown!! All I can recommend is that you check all your wiring and power connections. Make sure the power connection is properly grounded. Also, does the unit make this sound only with a specific source choice selected (ie...CD) or does it happen regardless of what source you were listening to before shutdown?
    Dan Madden :T
    • Glen B
      • 1106
      That model Rotel amp has no output relay to disconnect the speakers. What you're hearing is the sound of the power supply main filter caps discharging. It's nothing to be concerned about, just an annoying sound.
      • Jj157
        • May 2015
        Thank you both for taking the time to reply!i discovered that the sound comes only from the right speaker and only after i used the amp for more then 1 hour. Does this still mean it is related to the powersupply? I have someone in my family that is good with electronics. Is there something i can have him adjust or replace?
        • Glen B
          • 1106
          One channel or two channels, same issue of power supply discharge. An output relay solves the problem of hearing amplifier turn-on/turn-off noises. Manufacturers may emit relays in the interest of sonic "purity" or to reduce costs. Most such amps rely on DC rail fuses and output fuses as the only protection. If the output stage suffers a catastrophic failure, it is possible for the entire DC power rail voltage to be dumped into one's speakers.
          At least with properly working DC detection/overload circuity and output relays for each channel, there is a greater chance they will open instantaneously, and disconnect the speakers. To retrofit output relays into an amp, the job has to be done properly, so as not to look like a hack job.
          I have retrofitted DC protection circuitry into amps that didn't have output relays, including my 1970s Phase Linear amp (popularly known back in the day as "flame linear"). Power to operate the circuitry in this case was obtained from the amp main power supply rail, through a voltage divider network (tiny PC board to the right of the two main caps),
            OMG, that PL is gorgeous!
            • bleeding ears
              RB1070 V's RB1080 any diff
              by bleeding ears
              Hi all,
              Can anyone tell me the difference soundwise between the RB1070 and the RB1080?
              At nearly double the price, does the RB1080 sound any better than the RB1070? (RB1080 = $1600 V's RB1070 =$900) Thats recommended full retail prices in Australia.
              30 August 2005, 10:16 Tuesday
            • fretman
              ASW300 sub - pulsing sound when "auto" powered off
              by fretman
              I just bought a second ASW300 sub to add to my system, used, on eBay. It works fine, except - as the subject says - when in "auto" mode, after powering itself down, it makes a strange pulsing sound, with a slight chirp to it. It makes this sound even with no amp or speaker connected, and...
              03 October 2009, 17:13 Saturday
            • csuzor
              the whine of RMB1075 during shutdown
              by csuzor
              Has anyone noticed that there is a high pitched whine from the surround right channel from the RMB1075 during shutdown from the trigger? Nothing from the other channels, just sR, and very repeatable. It's like a capacitor discharging itself, just as the red lights go out.
              Don't worry...
              11 June 2005, 23:40 Saturday
            • dyazdani
              PC Shutdown Problem
              by dyazdani
              I've got a strange issue - my wife brought a co-worker's PC home for me to fix. It runs fine (when it's running) but it randomly shuts down. The power doesn't just stop, it actually puts up the Windows shutdown/logoff screen and shuts down "normally." Sometimes it also shuts down on the...
              23 October 2006, 08:04 Monday
            • hitek57
              Connecting pre AND prepro to RB1080
              by hitek57
              Hi all,
              As mentioned in my earlier post, I just added an RB1080 to power my front speakers. And the result is, in a word, WOW. Soundstaging, detail and bass oomph are much better than with my other, ageing power amps -- B&K ST2002 and Marantz M500 monoblocks.
              I have...
              14 October 2004, 23:19 Thursday
