HELP! RSP 1068 right front channel w/6dB less output than Left or Center
  • gp4Jesus
    • Jan 2010
    • 60
    Subject line says it all. Discovered while adjusting levels w/Test Tone.
    I've swapped cables around - what ever is plugged into that output has less.
    The only thing I haven't tried is rebooting the unit - I don't know how!:M
    Tony
    Samsung 60" LED
    Outlaw Audio 976
    Samsung BDP, Dish Network
    BJC 10 ga - LCR mids, inside & out
    Canare 14 ga - LCR inside; CC outside
    LR: RTi A7 Triamped
    M & T: Rotel RB-981
    Bass: Rotel RB-980BX ->8ga in & out
    CC: Rotel RB981 -> CSi A6 Bi-amped
    SW: LFE - Sunfire; Audio Pro Evidence @ each corner
    Surrounds: Rotel RB981 -> RTi A3
    Power Conditioning & Distribution: APC H15, 4 Furman Miniport 20s; 3 dedicated 20A feeds
    I blew a tweeter using the test tone on my 1066 once.
    Are you sure your speakers are OK?
    • gp4Jesus
      • Jan 2010
      • 60
      I'm certain its NOT speaker. When I connect the RSP right chnl output to the left Chnl amp input, the LEFT chnl has reduced output
      Samsung 60" LED
      Outlaw Audio 976
      LR: RTi A7 Triamped
      M & T: Rotel RB-981
        Sorry GP, but I have no solutions to offer.
        Bumping in hopes someone else will.
        • mjb
          • 1485
          Select the FACTORY DEFAULT option from the DEFAULT Menu of the On Screen Display.
          See page 40 of the Owners Manual.
          - Mike
          Main System:
          B&W 802D, HTM2D, SCMS
          • madmac
            • Aug 2010
            • 3122
            I can't help but thinking that your speaker placement is the culprit. Where is your right speaker located and what is near it. Drapes or any sound absorbent material (Sofa....loveseat??) can dramatically reduce the output from a speaker. No matter how much you swap wires around to verify the output, a speaker who's volume output is being effected by it's surroundings will ALWAYS put out less volume in that location than others located in a more 'live' location.
            Just a thought.......
            Dan Madden :T
            • gp4Jesus
              • Jan 2010
              • 60
              It's NOT placement. Nothing in the room has changed in 2 years.
              Haven't gotten to reboot/reset yet. Will post when I get to it.
              Merry Christmas to all
              Samsung 60" LED
              Outlaw Audio 976
              LR: RTi A7 Triamped
              M & T: Rotel RB-981
              • gp4Jesus
                • Jan 2010
                • 60
                THANKS MJB!! Re-setting it to "default" worked!
                Hated having to re-do input configs & speaker levels etc, but it's a relief that fixed it.
                Now what to about that non-working volume knob...
                Merry Christmas!
                Samsung 60" LED
                Outlaw Audio 976
                LR: RTi A7 Triamped
                M & T: Rotel RB-981
                • wettou
                  Using white noise to aim and adjust speakers
                  by wettou
                  Using white noise to aim and adjust speakers AIMING and "LEARNING" SPEAKERS Here is a method for "aiming" ...
                  25 July 2010, 16:28 Sunday
                • Aussie Geoff
                  RSP 1098 Wish List V2.0
                  by Aussie Geoff
                • Stevebez
                  5 & 7 Channel Stereo RSP -1066 Sub Setup
                  by Stevebez
                  I have been enjoying listening to music over 5 channel stereo. I know its a sin to audiophiles, but hey I like being surrounded by the music and getting equal power in all corners.
                  The problem I have is in 5/7 Chnl Stereo the LFE channel is really weak. I have small speaker setup all...
                  31 March 2004, 05:33 Wednesday
                • whmacs
                  RSP-1098 Bass Calibration Observations
                  by whmacs
                  Hi All,
                  More of an observation than anything else, but I recently recalibrating my subwoofer using Digital Video Essentials. This disk has a 75db output level. So as usual I set the front left speaker to output 75db (77 on RSP-1098) with the speaker level set to 0db. I then cut over to the sub...
                  24 March 2004, 15:34 Wednesday
                • pchanj
                  Rotel RSP 1098 Multi-Input Channel RCA
                  by pchanj
                  I was hoping someone could help me with my Rotel RSP 1098. Although its old, I have fell in love with the sound that it has produced. I am using this in combination to my RMB 1095. I use the multi input channel to connect my Oppo 103D to the RSP 1098.
                  One day, I noticed that the center...
                  24 October 2015, 07:44 Saturday
