RT1080 wont power up
  • PiDD
    • 240
    Woke up this morning to find the tuner wont power. When I press the power the blue light will come on and off but the LCD wont turn on and no sound.
    Any ideas for repair?
  • PiDD
    • 240
    This is typical for me (and lucky) .. take it all apart... disconnect and reconnect all the wires and it works again!
      • 2901
      I had that same problem with mine once or twice. It seems like if you disconnect everything, let it sit, it then comes on without issue. Only happened twice I think since I've had it (which is a long time)...so I can't complain. But it is odd, because even the switch on the back doesn't seem to make it do anything, then one time it just starts working again.
      Glad you got yours working again!
      • dp19
        • 9
        You might want to check the trigger connection. Having a cable plugged into the trigger will stop it from turning on. A bad trigger jack could also cause this.
