Power Amp Recommendations
  • jim1961
    • Nov 2012
    • 357
    I currently own a Classe CA-100. I'd like to get to 200-250W of clean 8 ohm power. I was wondering what you guys might recommend in a used amp 2-4 years old as a used buy in the $1000-1250 range that wont be a downgrade in sound quality from what I already have.
    Misc:
    1) Id prefer it NOT be bridgeable
    2) Needs to be comfortable driving 4 ohm loads as well
    3) Power meters a plus (old school fascination)
    4) Needs to make full power with a 1V input
    • 4157
    Rotel is all I can think of that would come close , and that's only close. Maybe Parasound. The CA-100 is a nice amp. Or this https://app.audiogon.com/listings/so...nsington-md--2 200 watts in to 4 ohms.
    • jim1961
      • Nov 2012
      • 357
      Thanks for the reply, but I already have 200w into 4 ohms.
      • meb46
        Stage Two – What next to power the dirty audio addiction?
        by meb46
        Having spent many hundreds of hours over the past 10 years (and a fair chunk of Jon’s time - huge shout outs) in developing some ambitious three and four way Avalon Acoustics inspired floor-standers, it is now time to divert my attention to a much needed Power Amplifier upgrade. If you’re not familiar...
        11 December 2016, 09:13 Sunday
        Adding a power amp to a receiver
        by Andrew Pratt
        As more and more people look to upgrade their sound systems people often ask about adding a more powerful amp to their system. Quite often this obsession we like to call our "hobby" leads us on a quest to sonic nirvana. As a group we are frequently upgrading our speakers or source components...
        23 March 2002, 09:06 Saturday
      • NMyTree
        Technical Question: Pre Amp into Power Amp
        by NMyTree
        Hi.
        I have question regarding output voltage of my Vincent Hybrid SA-T1 Pre Amp. Is that the right term?
        I'm wondering if my SA-T1 has enough or adequate juice to be matched up with my Butler TDB 2250 Hybrid Power amp?
        I don't know much about these...
        14 May 2006, 08:01 Sunday
        Clean and inexpensive- Cambridge Audio 651W Power Amplifier
        OnTheBench.key by Jon Hancock, on Flickr
        The Cambridge Audio 651W is now my new go-to amplifier for small and portable for speaker measurements. I got spoiled by the Benchmark AHB2- the 651W isn't truly an AHB2 replacement, but it's as close as you have any right to expect...
        17 April 2016, 15:41 Sunday
      • yanies
        Rotel RB 1080 and 4 ohms
        by yanies
        I have a set of Magnepan MMG 4 ohms and a Rotel RB 1080 Power amp that supports 4 and 8 ohms
        Theoretically I read that 4 ohms multiply the power level
        Comparing to what I hear that doesnt happen in my case.
        Should I hear a bit more louder or double in this case?
        Or there...
        13 March 2009, 22:36 Friday
