Hello everybody!
I'm an Italian Rotel enthusiast and I'm looking for advice on my HT system.
Currently I have a RSX-1057, plus a RB 971 mk II power amp. I use it to drive a 6.1 system (front: 2 bookshelf speakers rated at 80W). Main use is HT (70%), but I appreciate a good stereo session every now and then. The 2-channel power amp is necessary because te RSX can power only 5 channels; furthermore it seems to me that it improves the sound, especially in pure stereo mode.
Recently I have found a cheap RB 976 mk II (6 channels x 60w or 3 channels x 150W) and I'm wondering how to use it to its best.
First option would be to go for a pre-processor, in the RSP line; in this case, would I have an improvement with a 1066 or should I go straight for a 1068/1069? (1098 and 15_ series are out of budget...).
My second option to use all the pre-amp section of the RSX, and link it to (both?) the power amps, but I don't know if that would make much sense.
Please also consider the following:
- at present time I do not have a blu-ray player. This is due to come in the near future, when I'll upgrade my video section to full HD. Nevertheless, I believe that the center back speaker is a plus even with 5.1 sources.
- I'm also willing to change the front speakers with two towers, as soon as I manage to rearrange the furniture in my HT room. I'm not a fan of loud music/effects, so I'll go looking for an average set of speakers (unless I can put my hands on a pair of Martin Logan, that is! In this case I might use 4 of the channels of the 976, bridged to 150W, to drive them)
- finally, I do not link my video sources to the receiver: I believe in connecting the video signal directly to the tv set/projector, so I don't really need a receiver/pre with a top notch video processor.
Thanks in advance for your comments. Any suggestion welcome!
