RSX 1065 surround processor problem
  • akble
    • Aug 2010
    My Rotel 1065 seems to only want to play 2 channel - the processor seems to have just quit- any ideas or suggestions would be appreciated
  • madmac
    • Aug 2010
    • 3122
    A definite 'bug' with the RSX-10** series of receivers!
    See my posts above on this issue. It is now quite clearly a 'bug' defect in the 10** series of receivers with digital sound processing. I sent mine back under warranty but they did not fix the issue. I am now asking them for another unit since they did not fix it properly and will obviously not play the unit for hours to witness the unit fail. See similar posts above on the issue!!
    Dan Madden :T
    • madmac
      • Aug 2010
      • 3122
      Rotel, upon me sending them a letter, agreed to replace my RSX-1056 for a refurbished RSX-1057. The shop where I bought the unit here in Montreal (Environnment Electronique) was helpful and stood behind me in my request for a replacement unit. It certainly pays to buy equipment from a store which stands by their products!.
      So far, the new unit works great and there's no more popping and sound cut out!!. Also, for whatever reason, this unit seems to 'sound' better than the 1056 !!?. Gotta say that I lucked out because my 5 year warranty was going to run out this November!!.
      All's well and ends well.
      Dan Madden :T
      • lmib
        Volume clicking RSX 1055, RSX 1065, RSP 1066, RSX 1056, RSX 1067, RSP 1068, RSP 1098?
        by lmib
        Hi all of you RSX 1055 and RSX 1056 owners,
        i have an interesting problem, for that I cannot find a thread in the forum. I was sure I read something about this, but I'm not quite sure.
        My RSX 1055 make a continues popping while changing the volume above 30. Under 25 it...
        20 January 2006, 06:19 Friday
        RSP-1066 / RSX-1055 etc. Frequently Asked Questions (FAQ)
        by Andrew Pratt
        Rotel has a FAQ available here that may answer some of your questions. We've added several points of our own as well below.
        1. How do I know what firmware is installed on my processor?
        Answer: Simply press and hold the mute button on the remote and it will be displayd on the LCD...
        15 April 2003, 14:08 Tuesday
      • Glenn
        rsx-1065
        by Glenn
        First a hello to all. I've been reading the Club Rotel posts and the FAQ for about a week now. I decided to join, as it sounds like a great way to learn more about HT/Rotel.
        I am in the process of upgrading my HT system. Now the proud owner of B&W 9NT's. Finally it's time for the...
        09 June 2003, 03:21 Monday
      • Victor Chan
        Facelift for RSX-1065?
        by Victor Chan
        Hi everyone,
        Been waffling between getting the RSX-1055 or the 1065 and was leaning on the 1065 for the supposedly better processor circuitry and torroidal power supply. Seem to remember someone mentioning that the RSX-1065 may be getting a facelift from Rotel sometime in the near future....
        29 January 2003, 02:45 Wednesday
      • Rob Baker
        RSX 1065 needed critical adjustment
        by Rob Baker
        Hi everyone....Have a question. I have a 4 year old RSX 1065 thats really been a great unit. I resently had a EPROM and Firware upgrade. Not long ago the unit started acting up by running hotter then it every had before and the cooling fans would run only after 15 minutes of very light use. Really...
        07 March 2007, 20:17 Wednesday
