Rotel 1068, volume problems
  • jamesdaman
    • Apr 2008
    • 136
    Hi guys got my 1068 set up and now completing a surround sound system. Im having real problems though. To get a good sound from it( im using a 1080 for L R and 1565 for center and surrounds) i have to have the volume at around 75-80. now when i have it that loud there is Alot of static high pitched sounds coming from all the speakers inc the sub. Its like lots of distortion with out a film even playing. I feel this is distacting from the sound(its distacting me enough to not be able to enjoy my system ). Im not sure why its doing this at all. My brother came into the room and he could hear it straight away, i really need help with this please guys. Any thoughts or ideas would be great
  • Opus007
    • Nov 2007
    • 454
    Try removing each source components you have connected to the 1068 and see if it goes away.Also have you tried different cables?If you are getting this on both amps I would not feel it is the amps but I would remove one and test in 2 channel then the other.It sounds like a component source problem.Does it happen on all sources?
    • jamesdaman
      • Apr 2008
      • 136
      im using a playstation 3 at the moment and i dont have a TV ariel where i am so i cant test it with that. Weirdly i watched band of brothers last night and although i could hear the hiss when i paused it, during the film you couldnt notice it and it sounded great. But i then flicked the watchmen on and it sounded all dry and mufflled almost. Im wondering if the watchmen isnt that well recorded?
      • jamesdaman
        • Apr 2008
        • 136
        im not starting to accept the hiss. But one big BIG complaint is the midrange, my girlfriend noticed this straight away. Its like theres no midrange, its all pinched and sounds like its got the volume turned down on it, very Very annouying
        • Opus007
          • Nov 2007
          • 454
          I would not acept the hiss either.It may be time to call Mike at Rotel and go through some trouble shooting procedures.Even if the unit is out of waranty ,tech support is free and they maybe able to pinpoint the problem.
          Hope this helps.
          • nealdb
            anyone elase have 1068 problems?
            by nealdb
            My home theater has a problem holding video signal: picture blacks in and out, especially on hidef channels. i have had comcast out to check signal, have tried various monitors (currently using Loewe Aquos), and cant beat this! dont have problems on any other tv in house. i am on second 1068 (dealer...
            21 April 2007, 18:54 Saturday
          • jimihx27
            1068 problems
            by jimihx27
            hello during playback of dvds if i pause fastfoward or go to the dvd menu and chose to watch previews there is no sound and the DTS logo is replaced with dolbypllx I have to turn it off and back on to get sound my dvd player is set to bitstream I have had the 1068 for only 6 weeks any help would be...
            18 August 2005, 21:07 Thursday
          • Steve_the_Hokie
            1068 and Rotel problems
            by Steve_the_Hokie
            I bought a 1068 used that was only a month old. The original owner thought it was too difficult for some of the family members to operate, which I didn't really find to be true at all. Anyway, I had the unit sitting around the house for a month in the box while I was deciding what 5-channel amplifier...
            22 August 2005, 17:01 Monday
          • hired goon
            RSP-1068 component video problems
            by hired goon
            G'day,
            I'm having problems with the component input/output of my RSP-1068.
            I finally bought a TV that has component input. I connected my set-top box to the TV via component, and got a great image without any problems after one hour of use. Next I connected the DVD player...
            29 May 2005, 04:59 Sunday
          • Opoc
            1068 Video Problems
            by Opoc
            Hello all, I just purchased my first Componet HT setup, 1068 and 1075 and I'm experiancing some issues.
            I am using a Comcast Motorola 6208 STB, Kenwood DV-502 DVD player (not progressive), and a Mits 65809 (owner's manual ). The Cable box and the DVD player are connect to the 1068...
            14 December 2004, 12:11 Tuesday
