rotel 1062 - help
  • joao_fr
    • Apr 2010
    • 7
    rotel 1062 - help
    hi
    I have a rotel 1062 that i have bouhgt in second hand about a week ago.
    i´m afraid that the amp as some problem.
    it makes some noise in high frequencies when is playing a cd or a mp3 file. like i was listening a vinyl or so...
    some had experienced this problem?
    thanks
  • Opus007
    • Nov 2007
    • 454
    Originally posted by joao_fr
    hi
    thanks
    joao_fr
    Welcome to the forum.Have you tried other inputs on the 1062?Does it happen only on the cd input?Have you tried another cd/mp3 player or are you streaming audio from a pc?Do you have it hooked up to any other sources and does it do it on them?Do you have a loose or bad connection?Have you tried swapping out cables?
    • joao_fr
      • Apr 2010
      • 7
      i have tried all off that sugestions e the noise still remains.
      when the amp goes hot i thing the noise reduces...
      • Opus007
        • Nov 2007
        • 454
        I would contact the seller as sounds as though you got a bum deal.When you bought it were you able to demo it first or is this a ebay or audiogon sale?
        If it is a ebay sale you are probably going to take a loss.You can also call Rotel support.Hope it works out for you.
        Shaun
        • joao_fr
          • Apr 2010
          • 7
          it was a private sell.
          but the seller says that it all right with the amp.
          he says that the problem is from the recordings or the source.
          in fact the noise its only in some cds or files. not in all of them.
          thanks
          • Opus007
            • Nov 2007
            • 454
            Are you using a cd player or streaming audio from a music server(PC) ?
            • joao_fr
              • Apr 2010
              • 7
              i´m using both.
              but 90% of the time i´m using a squeezebox connected to the rotel
              • Opus007
                • Nov 2007
                • 454
                i´m using both.
                Really sounds like a source problem.
                • joao_fr
                  • Apr 2010
                  • 7
                  do you think a DAC will solve the problem?
                  the DAC will eliminate the fssssss noise?
                  • Opus007
                    • Nov 2007
                    • 454
                    So it only happens on certian cd's and only sometimes with music from the squezebox.I am not sure a external dac would solve your problem.
                    Do you have the cd player, squeze box and 1062 pluged into a power strip or a power conditioner? Does it happen on the same cd's at the exact same part of a song everytime?
                    What exactly is the noise you are hearing?
                    • joao_fr
                      • Apr 2010
                      • 7
                      the noise is like i´m listening a vinyl whith litle scratches
                      • joao_fr
                        • Apr 2010
                        • 7
                        i´m using a cheap power strip
                        • Opus007
                          • Nov 2007
                          • 454
                          Try going straight to the wall outlet.See if that helps.If not I am stumped.Maybe someone else will chime in here and offer a suggestion.
                          • Wilfred
                            1066 DD-EX and MP3
                            by Wilfred
                            The user guide suggested the some DD-EX discs have incorrect flag and the 1066 might not be able to auto-detect them. Is this the case for "Star Wars II" and "Lord of the Rings"?
                            Also, does any one here use the 1066 to decode MP3s? Just to test, I tried feeding MP3...
                            24 June 2003, 01:26 Tuesday
                          • RobG1
                            Crackling noise with Rotel 1062 amp
                            by RobG1
                            I went on vacation for a few days and when I came back I noticed a crackling interference coming from 1 speaker. I traded speaker cables at the amp and the noise went from the left channel to the right. It does this no matter which source I select. The noise varies in intensity and nothing I do seems...
                            22 September 2009, 10:16 Tuesday
                          • anachronist
                            RA-1062 noise floor
                            by anachronist
                            I own the RA-1062 and am very content with it's sound and mechanical quality. But, I have one problem with it: Driving my highly efficient horn-type speakers (102dB 1W/1m) it exhibits a soft but noticeable noise floor which is audible at my listening position about 10 ft from the...
                            12 September 2006, 08:54 Tuesday
                          • SGT
                            Rotel ra-1062 transformer hum...
                            by SGT
                            Hello all,
                            just joined the forum after desparately googling out a solution for my problem: brand new Rotel ra-1062 (integrted amp) has developed audible hum near the transformer area. It can be heard from about 10-15cm (4-6in), but it changes the pitch to a higher frequency and level...
                            18 July 2005, 20:13 Monday
                          • Jamil
                            RCD-1072 and RA-1062 with RB-1080
                            by Jamil
                            Rotel fans,
                            I recently purchased RA-1062 to power my 2 channel setup consisting of Era Design 5 speakers. The audio source is RCD-1072. Although the setup is quite pleasing to the ears I get the feeling that having a little more oomph in the watt/channel section will really help the...
                            21 May 2007, 22:40 Monday
