Hi all I've owned my 1067 for four years without a problem until today. I was listening to some music a medium volume, when all sound cut out. I cannot get any sound on any channels appart from some low sound from the sub. Are there any fuses I can check or would be likely an internal problem. Thanks for any help/advice, thought I would try here before the monumental task of unplugging everything and sending off to International Dynamics for repairs. Jeff
Help with my 1067
Tags: None
I haven't tried that model. But I'm sure the fuses are located so that they're easily accessible. If it is a blown fuse replacing it is easy. The manufacturer is irrelevant but the numbers on the fuse must be the same.
The fuses look like this. http://www.drillspot.com/pimages/425/42518_300.jpg
If it is a blown capacitor you can also replace it yourself, but that requires soldering skills.
A blown capacitor will look like this. http://i29.tinypic.com/2e504rm.jpg- Bottom
Jeff,Originally posted by Raaf HornetHi all I've owned my 1067 for four years without a problem until today. I was listening to some music a medium volume, when all sound cut out. I cannot get any sound on any channels appart from some low sound from the sub. Are there any fuses I can check or would be likely an internal problem. Thanks for any help/advice, thought I would try here before the monumental task of unplugging everything and sending off to International Dynamics for repairs. Jeff
Welcome to the forum.If the fuses are good then you may have a bigger problem with the digital processing board.There is a way to test this but you would need a seperate amp and use the multi channel inputs and preouts as it bypasses the digital board.Let us know the out come.- Bottom
by tomasitoHello,
Has anyone changed the fuse in a RB-1095.
I don't get audio coming out of the rear channe, I think one of the fuses is blown. I opened the 1095 and the fuses are buried way in the PCB.
I experienced this with the 1080, It was a blown fuse. The fuses in the RB-1080...-
Channel: Club Rotel
by MitchellHas anyone found a long term solution to the 1080 fuse issue?
Some of the blown fuse posts seem to have started in early 2004. Has anyone who has blown a fuse managed to go at least 6-8 months without blowing them again and if so did they leave it on all the time, not use trigger or some combination?...-
Channel: Club Rotel
by ZissouHave what until today was a perfectly functioning Cinenova 5.
Well I have had an issue, not a small one, and am very upset with Earthquake's response. We had the system on playing a movie as background noise when I heard a loud POP and a strange noise I'd never heard before. I glanced back at...-
Channel: Audio Hideout
by rantzmarHelp.
I think I have a blown fuse in my RC1090 preamp. I took of the cover and saw that the fuse had a clear cover over it with a warning do not remove unless a trained tech. I suppose the warning is because of the power supply, but by just looking at the fuse it looks broken. Its a very...-
Channel: Club Rotel
by kingwilliamHi all...
The problem: My RB-991 blew its main 12-amp fuse the other day (the fuse you can easily change from the back). I tried 10-amp fuses, but blew three in a row. No other components or speakers were hooked up to the amp. I unplugged the amp from the wall before swapping fuses....-
Channel: Club Rotel
- Loading...
- No more items.
