RB-1080 no sound on left channel
  • tomasito
    • Dec 2009
    • 16
    I m new to the forum. But I had my RB-1080 for 3 years now. Last night, I notice that the left channel has no sound.
    I had this issue before earlier in the year. Rotel told me to check the fuse of the left channel. It was blown,and I replace the fuse. It fix the problem.
    This time I checked the fuse, it was not blown. But I change it anyway. This time it did not fix the problem.
    I did a minor trouble shooting pinpoint where the issue is. It is now my amp, it is not my speakers. I swap the left and right input coming from my amp. The results leads me to conclude that it is the RB-1080.
    any idea, what might be the issue.
    Is there a way to reset the RB-1080?
    Thanks and Happy new year to everybody
  • Glen B
    • 1106
    Each channel of Rotel amplifiers usually has two fuses for the positive and negative power supply rails. Check both of them. Note that if you should replace a fuse and it blows a second time, don't do anything further until you contact Rotel. Repeatedly replacing fuses and powering up your amp could result in more extensive damage, as another member here found out recently. You reset the amp by pressing the front panel power switch. It does not sound like you have a protection circuit issue as both channels would be out.
    • tomasito
      • Dec 2009
      • 16
      That's good info, I thought that it is only 1 fuse. I will check.
      thank you
      • tomasito
        • Dec 2009
        • 16
        You are absutely right there was a second fuse. It was blown!, I replace it and there is sound coming out.
        I'm so happy ...... Thank you very much for the tip
        • tomasito
          • Dec 2009
          • 16
          Glen B,
          Happy New year to you and everybody on the forum
          • Glen B
            • 1106
            Great news. If you should blow rail fuses again in the near future, take a close look at the impedance of your speakers and how loud you're playing them. The rail fuses should only blow when the output transistors fail or are called upon to deliver too much current during normal operation. Happy New Year to you too.
            • tomasito
              • Dec 2009
              • 16
              I am using Polk Audio LSi9, I can not remember the ohm of these speakers.
              • srb
                • Oct 2004
                • 311
                The LSi9's are 4ohm 88dB speakers, which should not be too difficult for the RB-1080 to drive.
                I don't know what you're using for speaker cable, but hopefully it's something along the lines of 12 - 16 gauge (with all strands intact) and not the Radio Shack 24 gauge speaker wire.
                Steve
                • audiofiyle
                  Another fuse post. Help!! my RB-1090 needs you
                  by audiofiyle
                  Hi guys, I need help here. Last night I heard a pop, and my left channel went out. The reason is because I had a record cleaner plugged into the same multi outlet with protective circuit as my preamp. Usually I never have a problem, but the nitty gritty machine makes a noise when you shut it off. Dumb...
                  12 September 2009, 07:34 Saturday
                • sajaga
                  RB1080 just serviced - 6.3A fuses again!!
                  by sajaga
                  Hey all,
                  my RB1080 died a few weeks back - the old no left channel trick!!
                  I am local in Melbourne and dropped it off to International Dynamics in Richmond. I explaind to them what Aussie Geoff had gone through with them personally, as I am sure many of you all have in your various...
                  22 March 2005, 23:34 Tuesday
                • Stoopalini
                  Acdom 545 -- Left Channel Not Working ....?
                  by Stoopalini
                  I bought an Adcom GFA-545 about a month or so ago and have been using it to power my 100 Watt DVC 12" Realistic Ported Sub. I bought the amp for a Sonosub project that has been put on hold until my 12" Shiva shows up.
                  Yesterday, 2 Aura Bass Shakers showed up and I finally got...
                  30 August 2000, 19:15 Wednesday
                • red71rum
                  Rotel RMB-1075 and left surround not working....
                  by red71rum
                  I have wanted a Rotel amp for some time and because my wife does not understand my home theater obsession, I bought one used from Craigslist. I had asked the only owner all kinds of questions and finally bought it. It came with a like new manual, untouched warranty card amd two T6.3 250V(I think that's...
                  10 February 2016, 09:12 Wednesday
                • rotel&energy
                  Blown left channel (RB-1080)?
                  by rotel&energy
                  Hey guys,
                  This is my first post in a long time, and unfortunately I'm going to open up an old issue - blown left channels on RB-1080s. I've had my 1080 for over 2 years, using the 12 volt trigger, without any problems. Just the other night, I came into the family room and noticed I...
                  21 June 2006, 10:58 Wednesday
