Hi guys, I need help here. Last night I heard a pop, and my left channel went out. The reason is because I had a record cleaner plugged into the same multi outlet with protective circuit as my preamp. Usually I never have a problem, but the nitty gritty machine makes a noise when you shut it off. Dumb on my part, but anyway I lost the left channel.
I decided to check replace the fuses in the 1090 to be sure. When I opened it up, and being I am blind I couldn't tell if the left 2 fuses were 100%. So I decided to change them all. Well, the right side went in no problem, but when i tried to replace the left 2 fuses it sparks, and won't let me replace them!!
The unit has been powered off for 15 hours!! What the hell is going on? It' not
plugged in, and not conected to anything else plugged in. Can anyone help me here. thanks for any feeback.
Tommy
Tommy
