Oppo BDP-83 with Rotel 1069 issue
  • chanlon
    • Sep 2003
    • 188
    I'm getting no sound from the Oppo connected to a Rotel 1069 via HDMI.
    The picture is fine. However, I get no audio. I have LPCM selected in the setup menu for HDMI Audio options. The Secondary Audio is turned off. The output resolution is set at 1080p (Pioneer 141FD). The Primary Output is selected as HDMI. Mute is not activated on either component. Volume is up.
    The Rotel is selected to accept HDMI audio for the specific video input.
    2CH PCM remains on the Rotel display. It should be displaying multi-channel for blu-ray and 44.1Khz for CD's. I'm at a complete loss here.
    Any suggestions out there?
  • chanlon
    • Sep 2003
    • 188
    Ok, there is another kind gentleman on another forum who helped me identify a hdmi handshaking issue with the Rotel 1069 and my pioneer display.
    Once I disconnect the Pioneer HDMI connection, I get audio.
    It looks as if audio is being passed to the TV, but the TV don't want audio.
    This means the Oppo has to handshake all the way through to the display to verify copy protection, etc., and that could be the issue because the display may very well be set to say it doesn't WANT audio over HDMI.
    Problem is, Within Rotel's "HDMI Audio Mode," I have "AMP Mode" selected so that it DONT pass audio signals to the TV.
    Geepers. On another input I'm using a PS3 successful with all of these settings. But the Oppo won't work. Why does the Rotel work with the PS3 and not the Oppo? Anybody?
    • TommyV
      • Feb 2007
      • 425
      Because HDMI is a screwy interface and every company is left to try and make sense of it their own way.
      • mjb
        • 1485
        The 1570 should be in "AMP mode", the manual says in "TV mode" there is no audio output from the 1570. You selected HDMI audio, so thats correct. Perhaps there are some more settings in the Oppo? And also check you're using the latest devices firmware.
        HDMI can be very frustrating! What started as a good idea has just ended up a headache. I wonder what designers think of it, because if it were easy to implement, I'm sure we wouldn't be having all these compatibility problems.
        - Mike
        Main System:
        B&W 802D, HTM2D, SCMS
        • chanlon
          • Sep 2003
          • 188
          Frustrating.... Its tough to explain how I'm feeling. I have the latest firmware on the players. I have searched the web far and wide.
          I can't believe there are not people out there with an Oppo, Rotel and Pioneer combination.
          I sent an email to Rotel Tech Support. I'll have to wait to hear back from them. I have always found them great to deal with. It might not even be a Rotel issue anyways.
          • TommyV
            • Feb 2007
            • 425
            Only other thing you could try is just plug the Oppo into the HDMI jack and same cable that you are using and getting audio to see if that changes anything. I do have an Oppo 970HD hooked to my 1069 and there are no issues using HDMI for audio and video.
            • chanlon
              • Sep 2003
              • 188
              I tried that as well. Unfortunately, that didn't correct the problem.
              Furthermore, I had the Oppo 970HD before I bought the bluray - it worked perfectly.
              Thanks anyways.
              • june
                • 907
                PLAN B: Use the multi-channel inputs for sound.
                I have a rsp-1068 with a panasonic bd-55. I have issues with HDMI, only use it for video purposes.
                June
                • chanlon
                  • Sep 2003
                  • 188
                  I owned a 1068. This was the PRIMARY reason I got rid of it. Too many cables!
                  Now I have one cable that don't work but looks good. Ironic isn't it?
                  • Kevin D
                    • 4601
                    Is your TV at the latest firmware?
                    Kevin D.
                    • june
                      • 907
                      chanlon,
                      i need to take the course on hiding cables. but great sound trumps too many cables. "CHOOSE YOUR PAIN"
                      June
                      • chanlon
                        • Sep 2003
                        • 188
                        Kevin,
                        In the process of checking out the Pioneer firmware.
                        I also identified that the Apple TV and Xbox 360, connected to the Rotel 1069 do not pass video and audio either. Once again, if the HDMI is disconnected from the Pioneer, sound returns.
                        The Rotel and Pioneer combination really don't like one another at this point.
                        • mjb
                          • 1485
                          And you're sure you're in Amp mode? Have you tried playing with this setting?
                          Do you see the Rotel OSD on the Pioneer? That must work, as its not protected.
                          Can you try a component connection to the TV? The AppleTV also has Component outputs, so that should work fine too.
                          - Mike
                          Main System:
                          • TommyV
                            • Feb 2007
                            • 425
                            Yea my TV is a Pioneer Kuro but not the same one you have and every HDMI component I have hooked into it works fine Audio and Video.. I would double check the setup menus on you 1069.
                            • chanlon
                              • Sep 2003
                              • 188
                              TommyV - are you using an Oppo bluray player?
                              Also, is it connected to the 1069 only through HDMI? Is this connected to the Pioneer to HDMI?
                              And...what model Pioneer display do you have?
                              Sorry about all the questions.
                              • TommyV
                                • Feb 2007
                                • 425
                                No as I said I above mine is an Oppo 970HD. Yes I do use HDMI into the 1069 and then into my Pioneer with no problems. My Pioneer is the PDP-5080HD. I could test my XBox 360 but you should just confirm first you have the right settings for that input set in your Rotel.
                                Also check your Rotel firmware. Make sure you do not have one of the older versions.
                                • vsteel
                                  RSP-1069 audio/video problems
                                  by vsteel
                                  Ok, here are my problems.
                                  1. I can't seem to get digital audio out from the 1069.
                                  All of my analog signals go through just fine. (tuner, cd player. etc...)
                                  I have a cable box and PS3 both hooked up to the 1069 through HDMI cables (cables are 1.3a certified.)...
                                  14 June 2008, 17:00 Saturday
                                • rum
                                  RSP 1069 HDMI handshake issues
                                  by rum
                                  1) Having the following issue with HDMI connections and need help
                                  Panasonic BD60 BluRay Player Connected to HDMI 1 of RSP 1069
                                  RSP 1069 HDMI out connected to Panasonic Viera 42 inch Plasma.
                                  DVD/CD Player Denon 1920 connected to HDMI 2 of RSP 1069
                                  Get pink and tint...
                                  22 March 2010, 05:07 Monday
                                • wildpanda86
                                  RSX-1550 & Oppo BDP-95 Blu-Ray
                                  by wildpanda86
                                  I just picked up an Oppo BDP-95 as I was drawn to the high end DAC's and the fact that it uses a Rotel power supply so it's the closest thing to a Rotel Blu-ray player there is.
                                  Now I'm trying to decide if the Oppo BDP-95 is worth it for use with my RSX-1550 vs just using the BDP-93....
                                  21 August 2012, 04:25 Tuesday
                                • Ted
                                  RSP 1069 vs. RSP 1570 What Is Gained?
                                  by Ted
                                  I am currently using my RSX-1057 as a Pre to my RMB-1075. I currently use a PS3 as my Blu-Ray player, but after I have a dedicated Pre/Pro that I can use HDMI for both audio and video I'll get a dedicated Blu-Ray player too.
                                  What I'd like to know is, what do I gain in practical terms...
                                  20 February 2010, 22:47 Saturday
                                • EmilSA
                                  Death of a RSP-1069?
                                  by EmilSA
                                  I have messed up my firmware upgrade on my RSP-1069 and it seems I will now be paying some stupidty-tax as a result thereof.
                                  The local Rotel agents in South Africa can replace the digital board at around $800, or send it UK, where there is some glimmer of hope in resuscitating it, but...
                                  06 March 2012, 06:46 Tuesday
