RSX-1560 and TiVo audio loss
  • grit
    • 580
    I just updated my firmware (courtesy of Rotel) to the "latest" version : 1.1.6. However, when I pause my TiVo (connected via HDMI) and then hit play again, there is no audio. If I skip back 30 seconds though, the sound comes back on.
    I presume this is a firmware issue with the RSX-1560. I thought I've read where some people had later updates than the 1.1.6 I have. Can anyone offer any insight?
  • Kevin D
    • 4601
    I have an issue with my Tivo where if the stream is interrupted (a lot of really quick skips or glitch on OTA channel) the sound will go out. Skipping back will fix the problem.
    My has done it from day one, yours just started with 1.1.6? I'm running a beta version of 1.1.6 and haven't had a chance to go to the final version. Best bet is to email techsupport@bwgroupusa.com just to let them know the problem is out there.
    You did do a factory default after the update right?
    Kevin D.
    • grit
      • 580
      It was with the original firmware (don't remember, but I THINK it was 1.06), AND with the 1.16 firmware. I've had the same experience with skipping back fixing the problem. I also e-mailed Rotel as you suggested. They were unaware of the issue and thought perhaps the monitor was causing the problem. i'll e-mail them back and let them know i'm not the only one.
      Also, the current firmware they are working on does not currently address any HDMI sync issues, so there are apparently no related concerns they have know about either.
      • grit
        • 580
        Ok, i've noticed something *kind of* new about this. I'm currently only using two speakers. When I pause and hit play, the receiver seems to think it should decode the audio as though I have 5.1 speakers. I can still hear music (if its there) or other sound that I suspect is part of the front left and front right 5.1 audio. However, as I have no center channel, there's no audio dialog. Again, when I back up 30 seconds, this goes back to normal.
        Thus it seems the Rotel "forgets" that I only have 2 speakers when I pause a show. Go figure.
        Has anyone tried a firmware update beyond 1.16?
        • ray5
          • 444
          I had the same problem, not just with DVR issue but even Blu-ray etc. Once I pause and then play again there is a audio pause of about 10 seconds. It was in the original and even after the 1.1.6 firmware, I have the 1570. I don't know if the 1.1.8 firmware resolves this issue.
          Ray
          • grit
            • 580
            I'll try the 1.18 tonight and see what happens.
            • grit
              • 580
              I finally updated the firmware on my 1560 to version 1.19. Between that and the 1.13 audio update, all of the problems are gone.
              As a recap - with only 2 channels connected, when I watched 5.1 or higher source material and paused the material, when I unpaused it, the receiver would revert to thinking I had all 5 speakers hooked up, and not downmix the center channel to the left/right speaker. It now works properly.
              Yea Rotel!
              • Miguel
                RSX 1560 firmware upgrade - help needed!
                by Miguel
                Hi everybody,
                I'm in the process of upgrading the firmware on my RSX1560 after obtaining the links and instructions from Rotel. This upgrade comes in 3 parts, main, video scaler and audio. Interestingly enough, there are 2 different computer programs that you use to flash the 1560 -...
                11 August 2009, 00:06 Tuesday
              • grit
                Help - firmware questions for RSX-1550
                by grit
                I have an RSX-1550 with some... issues. When I turn it on, it won't see my Tivo's HDMI output. I can fix the problem by switching to another video input for a few seconds, then returning to the TV, but that kinda irritates my wife. I believe it does this on other sources as well, so its not just the...
                31 July 2009, 13:16 Friday
              • Dmantis
                Rsx1560
                by Dmantis
                Whats up all?
                Anyone first off know the release of the the 15 series? I'm also wondering about the RSX1560. It looks to have built in ICE class D digital amps built in. 7x100. Thats pretty cool. 4u rack space total. Thats also cool. I'm wondering how it would do in a 7 channel home theater...
                17 September 2008, 05:09 Wednesday
              • Lexman
                TiVo, An Early Adopter's Tale
                by Lexman
                Folks, it's been maybe 8-10 months since TiVo was introduced, on the heals of Replay TV. At least Replay was advertised as " Coming" , some time before I had heard of TiVo. Actually, I think the first I heard of TiVo, was the night I bought mine. How's that for a spontaneous...
                22 August 2000, 21:31 Tuesday
                Ackkk!, TiVo/DVR malfunction
                by Lex
                got a malfunction of my bedroom Hughes TiVo/Directv unit (DVR), sigh. This is the 1000.00 original HD unit. ( I have 2 of these) I guess I am going to remove my main unit's hard drive and replace into the problem unit to verify if in fact it is a bad hard drive. It could actually just require a...
                12 September 2007, 08:55 Wednesday
