Help - firmware questions for RSX-1550
  • grit
    • 580
    I have an RSX-1550 with some... issues. When I turn it on, it won't see my Tivo's HDMI output. I can fix the problem by switching to another video input for a few seconds, then returning to the TV, but that kinda irritates my wife. I believe it does this on other sources as well, so its not just the Tivo.
    Regardless of that issue, I'd like to find out where the firmware updates are. I've seem people talking about them, but I can't find ANY firmware updates for the 1550 or 1560.
    My current version is 1.1.1, and after reading, it seems like they're nearer 1.6 and likely on the way (if not done) with 1.2.
    Any help is appreciated!
  • hifiguymi
    • 1532
    Rotel doesn't post them on their web site. To get them send them an e-mail at techsupport@bwgroupusa.com and ask nicely. It's a long process and there are three parts that can be updated. Because of that they don't post them on their web site.
    Eric
    • grit
      • 580
      Thanks. Got 'em.
      Now, can anyone tell me if a USB -> RJ45 is the same as USB -> DB-9 -> RJ45? I think I'm losing the COM port option, but as I dont have the cable, I cant test it.
      • hifiguymi
        • 1532
        They are different. You need an USB to serial adapter and then use the cable that came with the receiver to connect to it. Here is a thread that talks about a couple of adapters that are available if you don't have one already.
        Eric
        • raiderdave
          Firmware / Software Updates
          by raiderdave
          I recently purchased some Classe demo equipment from my local shop. I do not believe any updates were installed since they acquired the equipment. I would like to get everything up to date, but was wondering if it is necessary to install each update or will the most current version include all previous...
          14 February 2011, 14:35 Monday
          USB to Serial Adapter
          by Andrew Pratt
          Has anyone ever tried to connect to the Rotels to update the firmware using a USB to serial adapter? I'm looking to buy a laptop and not all of them come with a serial port anymore which might not be a problem if the converters work properly.
          12 March 2003, 21:21 Wednesday
        • Jonesthegas
          Upgrading my 1068
          by Jonesthegas
          I am about to upgrade the firmware for the first time. I don't have a serial port on my PC but have a serial to USB adapter. Will this work? I know some people have had problems.
          Alternatively, I could get a RJ45 to USB adapter and forget the Rotel cable. Has anyone tried this?
          29 August 2005, 11:28 Monday
        • BlackbirdM3
          Updating the software/firmware on a Rotel RSX 1067 in 2018...
          by BlackbirdM3
          I recently acquired a really nice RSX1067. What an amazing piece of machinery. After doing some research on here, it has the original install firmware and software. I found the downloads for the updated versions of both, however I have a couple questions.
          1. Does anyone have a USB to the correct...
          18 January 2018, 15:02 Thursday
        • chamath
          Rotel Firmware update -- info
          by chamath
          I would like to share my 2nd upgrade experience with you so hopefully you would not run into the same issues I had. I have a Rotel RSX-1057; however, the issue described below would apply to any upgrade as it was not a Rotel problem.
          Firmware: (1057)
          my system = 2.1.2
          03 December 2007, 15:04 Monday
