Power conditioner
  • rantzmar
    • May 2009
    • 98
    Power conditioner
    Just wondering...what power conditioner do you all use?
    BTW I have the Rotel rb1080 and rc1090 pushing Canton speakers...and man this is a very good combination. These speakers are even clearer than my Paradigm Monitor 7's. So transparent. I am really surprised at the Canton brand and wonder why its not as popular as the other brand of speakers in the good old USA?
    Two Channel Room
    Vincent SA-T1/Telefunken/Golden Lion tubes~Rotel RB 1080~ Musical Fidelity XRAYv8/XXXpsu~MMF-.7.1~2M Black-Grado Phono 1 Analysis Plus Phono Cable~Canton 830.2~ Analysis Plus interconnects and speaker wire.
  • style
    • 1562
    Hi rantzmar,
    I DONT use a conditioner....go direct an wall :T
    Your powerampli give you the best sound without dynamique loss....
    well in europa we don't have so much electricity up and down..
    Style
    • rantzmar
      • May 2009
      • 98
      what about the rest of your gear...CDP,PREAMP,SACD etc...
      Two Channel Room
      • miner
        • 900
        I have two - Rotel RLC-1040 and an APC H15 (basically the same unit). I have 2 RB-1092 amps, RC-1082 pre, RC-1090 pre, RCC-1055 changer, RC-1075 CDP, Rega P7 TT. I have tried both amps with and without conditioning (plugged directly into the wall) and I could not tell an audible difference.
        • Blindamood
          • Sep 2003
          • 900
          Also use the Rotel RLC-1040 and it works great. Even regulates voltage when needed. I plug EVERYTHING into it.
          Used to have an APC H15 as well, and had no problems with it either.
          Brad
          • rantzmar
            • May 2009
            • 98
            Well I just ordered a Belkin PureAV Home Theater Power Console PF31 because I want to be safe rather than sorry.
            Two Channel Room
            • kmcheng
              • 253
              I have had the Belkin PureAV PF30 for almost three years and have not had any problems with it. It is really there as a surge protector more than anything.
              • Glen B
                • 1106
                DIY balanced power with the 2-channel system. Belkin PF-60 with the HT system, mostly for its programmable switching/delay features and surge protection.
                • rantzmar
                  • May 2009
                  • 98
                  You guy make me feel like I did the right thing by adding the Belkin. When I first asked about it, and style said what he said, I was thinking of not buying it, but I see I did the right thing by all of your responses. I thought I read some place that the amp is fine by just plugging it into the wall because of some internal protection in the amp, and that may be so, but I felt that it was not enough, and besides, what about the rest of the gear...so I decided to get one. I thought, if I have one in my home theater, why not my two channel system.
                  Two Channel Room
                  • Nolan B
                    • 1792
                    I have a Rotel RLC 1040 and I really like it. I never noticed how all over the place my voltage is. It got to the point where settings in my cable box would reset as a result. After hooking up the 1040 problem went away. I also like to see how much power is being used, and the switched outlet works perfect to turn my plasma back lighting on.
                    All that with surge protection, central grounding and convenience!
                    The only thing I plug directly into the wall is my amp.
                    • Tomys
                      • 5
                      I've just bought the "Power Plant Premier", don't know is it a right decision or not ? has any one using it ?
                      • rantzmar
                        • May 2009
                        • 98
                        dont know if you have done the right thing, but that one gret piece of gear you have just bought. Its suppose to be a energy regenarator. If it does what it says it can do, then I would say good for you.
                        Two Channel Room
                        • rantzmar
                          • May 2009
                          • 98
                          OK the Belkin arrived yesterday and it works great. But the instruction book is kinda week. Why is it a good thing to have the amp on a delay when its turned off and on?
                          Two Channel Room
                          • Glen B
                            • 1106
                            You want the amp to turn on after the preamp to avoid thumps that could damage your speakers. You also want the amp to turn off before the preamp for the same reason. Turning the preamp on and off while the amp is on may cause any turn-on/turn-off pulse appearing at the preamp's output to be amplified and sent to the speakers.
                            • planitismetal
                              • 212
                              I am using it for 6 months now, and I have made too many tests...
                              Maybe "style" has right for the power amp direct to the wall main, (I cannot decide which is better),
                              but for all the other equipment it is the best in market (for me)!!
                              I will have the chance to try Systems & Magic BlackNoise 2500 this September (too long I know) and I'm considering Russ Andrew's The Ultra PurifierBlock-Ag with MegaClamp for filtering the power amp...
                              I had a communication with PSAudio, and they have told me this:
                              "When using the Premier, you must must must remember to respect the power threshold.
                              Do not let your Premier be connected to units such that they surpass the 1200W mark.
                              Anything past this may cause permanent damage to your Premier."
                              [U]
                              • rantzmar
                                • May 2009
                                • 98
                                Well that answers my question and makes perfect sense. Thanks Glen B.
                                rantzmar
                                Two Channel Room
                                • Mats
                                  1066/1075 with a line conditioner?
                                  by Mats
                                  hey folks.. new gear picked up this weekend with a panamax 5300.
                                  is it preferred to hook up the amp to the line conditioner, or will it prevent the amp from "being all that it could be"? also, how do i go about using the 12v trigger for the pre-amp and the amp? is this bypassed...
                                  07 April 2003, 08:23 Monday
                                • avab
                                  A line conditioner - who needs one?
                                  by avab
                                  Hi all,
                                  Am in the final phases of finalizing my home theater purchases. I have a question regarding a line conditioner?
                                  What buying tips do you have? Like - who needs one? Which one is sufficient?
                                  My current setup:
                                  Rotel RSP-1068
                                  Rotel RMP-1075...
                                  24 April 2006, 13:11 Monday
                                • spykids777
                                  Power Conditioner and Classe Amp
                                  by spykids777
                                  I have Classe CA5300 and 2 CAM 600 amplifiers and the SSP-800. I have noticed that depending upon the type of music or movie that I am watching my blue LED lights on the Amp start blinking (not blue and red). Currently I have them hooked to a Panamax 5100 power conditioner. Do I need...
                                  18 July 2011, 08:32 Monday
                                • Eliav
                                  Are your amps. plugged in directly to the wall Vs power conditioner ?
                                  by Eliav
                                  Hi All
                                  Has any of you experienced any audible diffierences ( particularly in lower frequencies reproduction) , when powering your amps through your power conditioner Vs the walls outlets ?
                                  My experience with Classe CAM 600 monoblocks is that Bass reproduction is slightly...
                                  13 May 2012, 13:28 Sunday
                                • jeweltone2002
                                  A51 transformer hum...Need power conditioner?
                                  by jeweltone2002
                                  I recently purchased the A51, and I am getting a hum from the transformer. The hum comes directly from the A51 unit and not through the speaker (it's not a ground loop problem). I send the A51 back to Parasound for repair and they replaced the transformer (very good technical support...
                                  04 November 2004, 00:06 Thursday
