the rb 985 in 5ch are 100w in 8ohm but what are the 2ch power?
rb 985 2ch power
Originally posted by jorgen68the rb 985 in 5ch are 100w in 8ohm but what are the 2ch power?
jorgen68,
I'm not sure I understand your question. The 985 is 100 wpc equally into each of the five channels. Each channel is separately powered and engineered. So any two channels will still be 100 wpc. If you only use 2 of the 5 channels, the 2 channels will not become something like 150 or 200 wpc channels.
Rotels ratings are typically conservative. My 1095 was about 15% higher in actual output compared to the rated specs.
If you are looking at getting more power for a set of speakers, like the mains, then the way to do it is by getting a more powerful amp.
Hope this helps.- Bottom
jorgen68,
In theory, what you say makes some sense. Only using 2 channels means more power for each. The problem lies with the power delivery for each channel. The design and parts for a 100 watt channel are fixed. Trying to push through more power through a defined area will not work. The cost of parts and engineering to deliver more power would push the cost (and price) up of the amp. I believe that's one reason why the 'high end' amps like Classe, Mac, Krell, etc. cost so much more. Their power delivery is awesome.
Since a company like Rotel makes several choices in 2 channels amps, I can see why they would have a 'fixed' 100 wpc multi-channel amp.
by gp4JesusThe Rotel RB 985* manual lists a “DIN 4 ohm” power spec @ 220 Watts. How does that compare to its 100 X 5 WPC RMS, all channels driven, into 8 ohms? That is, anyone care to guess at a 4 ohm rating for this amp*?
I googled DIN. The article suggests (my words) a DIN rating comes off...-
Channel: On the Bench and in the System
by WillempieThanks for having this forum as it is appreciated. I have a RSX1550 that has previously required repairs which involved some amplifier circuit board replacement done at a non Rotel facility. Now I have other issues on which advice of any kind would be appreciated. Outputs for two channel such as stereo...-
Channel: Club Rotel
by excetara2Basically I am deciding to go with a newer Rotel the 976 which has digital inputs, which I need. This is for a 2ch stereo system only conserned with sq. Or I am going to go with a Rotel 980 and get a Marantz DP870 which is there digital processor to use as a DAC into the 980. I am wondering which will...-
Channel: Club Rotel
by rstallardI'm a LTLFTP (long time lurker, first time poster). I just replaced my old RTC-965 with a RSP-985 (sorry but that's all I could afford). Is it me or did I just make a quantum leap in sound quality for both 2ch and 5.1 (using DTS/THX)???
Second question. I literally BROKE the main...-
Channel: Club Rotel
by ac81017Hello club Rotel!
I have next to no money, and I don´t want to put myself to shame! but, I have a surround system, sony 1070qs amp with B&W 602s3´s, lcr 60, asw750 sub! I feel that my Sony amp has the perfect sound for my ears! But, I would like to boost the sound buy getting an...-
Channel: Club Rotel
- Loading...
- No more items.
