Pre-amp to power amp cables?
  • KyaDawn
    • Mar 2008
    • 268
    I just bought a Rotel 1092 to drive my new B&W 802Ds. For now, I will be using a Denon 4308 as the pre-amp for my 802Ds. I was wondering how good should the RCA cables be that I use to connect the Rotel 1092 to the Denon? Must I use expensive cables, and do you have any recommendations?
  • Legairre
    • Jan 2002
    • 231
    Monoprice has nice cables at great prices. I use the HQ RG6 cables and they are great. http://www.monoprice.com/products/su...02&cp_id=10236
    "What do you mean it's too loud? My ears aren't even bleeding yet!"
    Radden Home Theater
      • 4158
      I would check with Doug (Lex) on this site for cables . He made all of my cables , and I wouldn't go anywhere else.
      • bnieman
        • 202
        I agree with Legairre, Monoprice rocks for RCA and HDMI cables. I also really like Monoprices banana plugs. I go to Blue Jeans cable for my speaker wire (they also have really nice banana plugs too, a little more costly than Monoprice's)
        Anyways, I am getting off subject. For RCA Cables: Monoprice. You can even get them bundled together for 5.1 inputs. Great quality, great price. What more can you ask for?
        Guide: Ripping DVD-Audio Discs (DVD-A) to FLAC in Windows
          • 4158
          Ummmmm.... Lemme try this again. The owner of HTGuide makes very good cables. Worth checking out.
          • Kreyfish
            • 18
            The subject of cables (both interconnect and speaker) is one of immense debate, but in answer to your original question, my opinion is this-:
            Signals being transmitted from a source to a preamp or a preamp to a power amp are line-level, or of low voltage/current and therefore are more prone to picking up interference that is of a high enough level to have audible effects on them.
            For this reason, the interconnects that you are asking about are in my view very important to your setup.
            Capacitance should be relatively low and cable impedance should be 75ohm for digital and 100ohm for analogue and they definitely should be shielded.
            I have made all of my interconnects using Belden 89207 for analogue and 89259 for digital with Eichmann bullets and Cardas quad-eutectic silver solder. The shield on the analogue cables is connected to the ground pin at the source end and grounded through a 1uF ceramic disc capacitor at the destination. This gives no continuity at signal frequencies to prevent multiple paths and ground loops but continuity at RF frequencies to provide effective shielding. I have spent many hours experimenting with this and am probably a bit anal about it. ops:
            However, I have heard nothing but glowing reports about Lex's cables and believe as a forum sponsor he should be supported. If you do a search on this forum about his products, you will see that you will not go wrong, and might just unleash some hidden talent in your system. :T
            It is easier to ask for forgiveness than permission...
            • chrispy35
              • 198
              How is cable impedance impedance important at analog audio frequencies? How long of a cable are we talking about here?
              • bnieman
                • 202
                Uh oh... Let the great cable debate resume!!!
                • Kevin D
                  • 4601
                  Sorry.. Have to cut it short here. Per the rules of the forum, cables can not be the main topic of discussion.
                  Kevin D.
                  • thefleu
                    Interconnect cables between preamp and amps
                    by thefleu
                    Hi folks,
                    I just sign up in your great forum but read it since I buy my RSP-1066 a few monthes ago, I must say "sa déchire grave" which means "it's really cool" in french.
                    I intend to use some QED Qunex 3 between my 1066 and 3xRB-03, did any of you...
                    14 September 2005, 08:21 Wednesday
                  • Adespota
                    Need amp suggestions for 802Ds
                    by Adespota
                    OK today we bit the bullet and ordered a pair of 802Ds to be our front speakers. Our preamp is a Linn Unidisk SC with Synergistic Research active Sig 10 speaker cables and the X2 active interconnects. Our current fronts were 804s which will become our rear speakers.
                    But we need to replace...
                    17 May 2007, 21:47 Thursday
                  • ED K
                    Speaker cables for B&W 802D
                    by ED K
                    Now that I have my B&W 802D speakers and Bryston 7BSST mono amps, The next question is speaker cables. At some point in time (when I get some $s), I want to biamp the 802Ds with another set of Bryston amps. So,,,I need some help in selecting speaker cables so that I can get the limit out of the...
                    12 December 2005, 15:24 Monday
                  • yanies
                    Rotel RB 1092 advise
                    by yanies
                    Hello everybody
                    I repost my last post with some changes that I found out
                    I just got 3 days ago the Rotel RB1092 to test it at home that my dealer gave me.
                    I compare it with RB 1080 and I have to admit that I am a little confused.
                    The 1092 should...
                    14 July 2008, 10:00 Monday
                  • Boone38
                    Have you heard or watched the RDV-1092
                    by Boone38
                    I am still using the 1060 and wondered if anyone has listened to or watched the 1092. I just found out that my dealer has a few in and the have it set up with the 802Ds. The system they are using to compare it with is the high end Meridian. BIG cost difference. 1500.00 vs 4500.00. Of course they feel...
                    17 June 2006, 11:27 Saturday
