Troublesome HDCP Issue with RSX-1058 - Please Help
  • rcrcr
    • Jan 2009
    • 10
    Hello:
    I am having an annoying issue with a newly purchased Rotel RSX-1058.
    Currently I have this unit connected to a non-HDMI Fujitsu plasma display via component cables.
    I have a non-HDMI Sony DVD player (NS999ES) connected to the Rotel via component cables.
    The problem is as follows: Menus and unprotected content on DVDs play back fine through the RSX-1058 to the plasma.
    But, at settings of 720p or above, as soon as a movie or other apparently "protected" content begins to play on the DVD, the screen goes black.
    I understand that HDCP protected content from HDMI sources won't be output on the component out of the Rotel.
    HOWEVER, as I mentioned above, the source here is an old school component DVD player connected to the Rotel via component cables, not HDMI!
    If I disconnect the component cable between the Rotel and the DVD player and reconnect using an S-Video cable, the symptoms are the same: menus and and "free" content displays, and other content produces a black screen.
    Why is this happening? How can I work around it?
    I don't understand why an analog signal would be selectively blocked from output on the component output of this Rotel for DRM reasons. Has Rotel gone too far with their HDCP implementation on this unit? Is this a bug? Would an another brand DVD player work better?
    How is the Rotel even detecting "protected" content over an analog link?
    I'd appreciate any guidance or advice on this issue. I am in a bit of a corner on this one.
    Thanks.
  • Kevin D
    • 4601
    You will need to set the unit to 480p when on the DVD player. The 1058 always runs the non-HDMI inputs through the scaler. An ever increasing number of DVD's are coming with a 'no scaling without HDMI' flag. When this happens the 1058 is not allowed to scale it past 480p over anything but the HDMI output.
    Of you course you will have to switch it back to 720p/1080i when done or it will down-scale any of your HD sources ran through.
    Your best bet is to pick up an HDMI to component box that strips HDCP. The HD-Fury2 should work fine.
    You might try enabling HD BYPASS in the menu. I'm pretty sure it only bypasses the HDMI inputs, but it might leave the incoming component resolutions alone letting 480p from the play just pass through.
    Kevin D.
    • Patrick TX
      1066 component switching question?
      by Patrick TX
      I have a new 1066 as well as a new Pioneer Elite Pro630HD RPTV. It only has 2 component inpus, as well as 2 HDCP DVI inputs. Right now I have no DVI devices, and 3 component devices. A Panasonic DVD-RP91K for 4:3 an non-anamorphic DVD's, and a Panasonic DVD-XP30 for everything else. I also have an HD...
      20 July 2003, 12:42 Sunday
    • unclemick
      RSX1057 vs. RSX1058
      by unclemick
      So in my hopes to find a deal on a 1058 to replace my 1057, I have a question. My 1057 suffers from lack of HDMI not to mention that the HDMI does only video. My question is, can the 1058 accept a component video input, yet output to one of it's HDMI outputs? My 1057 can't and I would love to just...
      27 September 2009, 14:28 Sunday
    • psrontom
      Non-HDCP FP, HDCP DVD player - how to?
      by psrontom
      I just got my SE 20HD projector, and am in the hunt for my new DVD player with DVI/HDCP/HDMI output. I'd rather not go Bravo D1 because of its poor reliability issues... and it's the only non-HDCP player I know of.
      To my knowledge, one device can strip / decode the HDCP from the DVI data,...
      22 October 2004, 18:46 Friday
    • Kevin D
      Introducing Rotel's best ever Home Theater Component, the RAP-1580
      by Kevin D
      To be shown at Cedia next week and launching in November.
      Separates Performance in a Single Chassis
      Will have Atmos 7.1.4 and HDMI 2.0/HDCP 2.2.
      More info to come next week!
      Kevin D.
      10 September 2016, 10:16 Saturday
    • jam200
      Just Received My Rotel RSP-1582 HDMI 2.0a and HDCP 2.2 Upgrade
      by jam200
      Greetings everyone:
      I just received my Rotel RSP-1582 with the upgrade to HDMI 2.0a and HDCP 2.2. The cost was $300.00. If I had opted for just the HDMI 2.0 upgrade with HDCP 2.2, the cost would have been $0.00. Return shipping is included with both options. The HDMI 2.0a upgrade provides...
      05 September 2018, 15:55 Wednesday
