Replacement Power Cord
  • toledoguy
    • Jul 2008
    • 24
    I need to purcahse a replacement power cord for a Rotel RMB-1066 Amp. Nothing wrong with the old power cord, I purchased it from an friend and the amp works fine. I tested it with the power cord from my Rotel RB-1050 amp. Any suggestions on where to find a replacement power cord? Thanks
    • 4151
    There are umpteen million outfits willing to provide a power cord. From M*nster to Shunyata. What price range , and what expectations do you have for the change? If you just want a way to get 110 ACV from point A to Point B , there should be a plethora of options. I would check big box stores or local audio stores.
    • toledoguy
      • Jul 2008
      • 24
      I'm looking for a cord that is of the same quality of the Rotel Power cord that has been lost. I understand that there are quite a number of maufactuers out there. Interestingly enough, when searching a number of web sites, I have found 3 prong, grounded cords, and not the two prong cord used by the amps. I'm sure that there are those who will argue that a super expensive power cord is critical, but i'll go with the one that satisfies Rotel's requirements. It wil be plugged into a modertly priced surge protector/power conditioner.
        • 4151
        I've also noticed the majority of power cords are three prong. Have you tried a Rotel dealer? They should be able to get you one.
        • Wardo
          • 60
          isnt this forum owned by a cable company?
            • 4151
            CAT Cables is on hiatus , although it might not hurt to ask Lex if he has any left.
            • Kevin D
              • 4601
              The three prong cords will work fine with any Rotel piece. The third ground wire will do nothing.
              Kevin D.
              • toledoguy
                • Jul 2008
                • 24
                Will the three prong cords fit? The back of the Rotel amp I mean?
                • DrJRapp
                  • Apr 2003
                  • 1204
                  Yes... it is a standard connector
                  Jerry Rappaport
                    • 4151
                    That is the issue I've had while cable shopping for my CD player. The connection on the back of the player is two prong , and the recess is a specific shape. Having a hard time finding an upgrade that fits. :scratchhead: My amp has a hard-wired power cord , and I'm sort of on the fence with that procedure. I need to be pretty certain that the benefit will be noticeable to start that project.
                    • toledoguy
                      • Jul 2008
                      • 24
                      I'm not getting a power cord just to "upgrade", I assume the Rotel power cord works just fine. The court that came with the RMB-1066 was lost. The person I purchased it from had not used it in a little while and replaced the cord. So I'm not looking for an upgrade just a replacement.
                      • htsteve
                        • 1216
                        You're probably looking for something like these:
                        Or go to a computer store (like Microcenter) and find the powercord with the biggest guage on it.
                        Hope this helps.
                        • wettou
                          • 3398
                          Here is an other option:
                          NEW Signal-SafeTM IEC Power Cords
                          Signal-SafeTM IEC Power Cords replace the standard power cords provided with electronic components, and are available in multiple sizes, with standard or low profile, 90° angled plugs.
                          • Save space at the back of the rack
                          • Constructed of 14 gauge wire or 18 gauge wire (cable/satellite cords)
                          • Provides a cleaner, more organized installation
                          • Eliminates slack and loops caused by long power cords
                          • Signal-SafeTM design incorporates twisted wires to minimize disruptive AC magnetic fields
                          • Multiple length cords available to meet the needs of each situation
                          • Also available for user specifically with most satellite and cable boxes
                          • UL listed in the US and Canada
                          • toledoguy
                            • Jul 2008
                            • 24
                            Just in case anyone is interested, in my search for a replacement power cord I called my local Rotel dealer. Nice guy, he didn't have the part in stock, and actually recommended a part he might not carry. The point being, he was rather insistent that a high quality IEC power cord, better than even the one that comes with the Rotel Amps would be of benefit. His theory is that in a high current amp, like the Rotel Amps electricty is everything, thus, a cord that helps get the electricty with as little resistance as possible to the amp from the wall is of value. So now of I go to find something I like.
                            • Ron Reda
                              1066 Power cord replacement
                              by Ron Reda
                              Based on some discussion in another thread, I went ahead and ordered a VH Audio Flavor 3 power cord to replace the stock cord that came with the 1066 pre/pro. However, when it arrived today, I noticed that the cord had a three-prong female receptacle with a three-prong male receptacle versus a two-prong...
                              26 August 2003, 18:43 Tuesday
                            • RoMan
                              A/V power ac cable??
                              by RoMan
                              Hi all,
                              I was going to buy an Audioquest nrg 2 cable for my RSP 1570 when I noticed where you plug in the cord to the 1570 is only 2 prong. Much to my dismay I can't buy this type of power cord. Does anyone know if it would still fit even there is no ground prong(so to speak)?? I would...
                              11 October 2009, 20:50 Sunday
                            • beboram
                              Lifting veil - 2 prong to 3 prong
                              by beboram
                              Why did switching out all the 2 prong power cord that came with the receiver with a 3 prong regular cord of the same guage make my audio system come alive as if a sheer veil being lifted?
                              06 October 2004, 13:27 Wednesday
                            • Russ L
                              Upgrade Power Cord for RB-1070?
                              by Russ L
                              The RB-1070 only has a 2 prong female outlet for the power cord (while the RB-1080 has a 3 prong). If I want to upgrade my power cable does anyone know a brand that supplies a cable that will fit? I've searched everywhere to no luck. I hope Doug doesn't mind the question since he doesn't sell power...
                              30 July 2007, 17:08 Monday
                            • BWLover
                              Power Cord Question
                              by BWLover
                              So I got an RLC-1040 and the power cord that came with it was maybe 2 feet :M (on a good day). So I switched it with the power cord on my RB-1080. They were both 14AWG cords but the 1080's was 6 feet (long enough for my RLC-1040). Now the 2 foot cord is to short to be used on my amp. So now the cord...
                              17 August 2009, 04:36 Monday
