My first rotel product (tuner). need computer IO help.
  • c3lica
    • 11
    I just bought a Rotel rt1080. This is my first rotel product ever. My question is how do I use the IO Port. Can I just hook it up to my switch and access it like a router via http (I highly doubt this is in fact the way to do so). I am going to college for computer science so I would like to write a program to control it. I contacted Rotel but have not herd back yet. I have no idea how to hook it up and control is so any and all information is helpful.
    Also, is there anything I should know/do in regards to my new tuner. I am very new to high end audio.
    EDIT:
    have been doing some searching and found that ethernet will not work... it is a rs232 with rj45 jack. i am reading the rotel documentation so that shouldn't be a prob but if you have any tip they would still be appreciated.
  • Kevin D
    • 4601
    Should be able to look at the program posted here to get some ideas:
    It will control the RT-1080 and includes the source code.
    Kevin D.
    • c3lica
      • 11
      ahhh thanks, I saw that post but missed the code. that will same me lots of work.
      • PiDD
        • 240
        Have you ever used Girder... It has a serial interface. I only mention it because you sound like someone that likes to play with this stuff.
        • c3lica
          • 11
          I have not used it but I will deff check it out. For now I am trying to convert the VB6 code provided above to vb 2008.
          • Glenn
            2004 Rotel Product Catalog - flat panel display
            by Glenn
            I have a copy of the Rotel 2004 Product Catalog, that I've been intently looking through. As an aside don't you love how stereo equipment is always shown fully powered up, lights and displays on, TV's displaying vibrant images, all without a single cord in sight
            Back to the topic:...
            08 March 2004, 21:02 Monday
          • yanies
            RDG 1520 Tuner
            by yanies
            I was wondering if anybody knows about the upcoming new model
            RDG 1520 Tuner of Rotel comparing to the old RT1084
            I would appreciate your input
            Thanks in advance
            24 October 2009, 18:46 Saturday
          • audiofan
            Warranty on Rotel's product as second owner?
            by audiofan
            I read at rotel.com that the warranty is not transferrable! I know that many of you bought used Rotel amp. How do you handle it if there is a problem with the amp? Do you buy warranty from the third party and do you recommend good one?
            thanks a lot.
            22 August 2004, 13:10 Sunday
          • kobestonecold
            Just ordered ROTEL amp/pre amp/CD
            by kobestonecold
            Hi, i just order Rotel RB-1080 , RC-1090, and RCD-1072 for $5000 NZD.
            Is this a good combo for B&W 705? Is the price good? It is so hard to find Rotel's product in Auckalnd , New Zealand so this is the best i could do.
            2 more days to get it. I hope i made the right...
            30 September 2007, 16:42 Sunday
          • mfishmike
            Rotel 1065 and R969 remote problems, very disappointed with Rotel's product now.
            by mfishmike
            I've just received my 1065 back from Rotel for a major upgrade.
            When I change channels with the satellite dish, it automatically switches the audio mode to fm stereo and I have to use the remote again to reset it to the satellite receiver. This happens every time a change a channel...
            08 July 2008, 06:51 Tuesday
