Power issue with RB-1090 ? Help Please
  • Tapesh
    • Oct 2003
    • 21
    There is continuous a krrrrrrrrrrrrrrrr. sound coming from my speaker. Possibly power related issue.
    Connections CD Player Sony 555ES -> ASL AQ2004DT -> Rotel RB-1090 -> Polk Lsi9 Speakers
    Sound level increases as connections are made. Just speakers hooked on, you have to close to speaker to hear this.
    Connect PreAmp, you can hear this.
    With CD Player connected you cant bear this, it dominates the music.
    Solutions as suggested by Rotel Dealers, I tried Monster Strip with stage 1 filteration, it didn’t help.
    Tried every thing from that strip and then amplifier direct and sources from strip. Nothing changed ?
    Certain lights in the house make more louder.
    Should the amplifier be connected directly and it’s the reqources that are creating problem ?
    If good power cord will help ?
    Please help what am I doing wrong ? buy monster conditioners ? How come my receiver setup never picked up these problems in the current.
    Tapesh
  • ht_addict
    • Dec 2002
    • 509
    Start by disconnecting your TV coax from the wall to see if it helps. Get an extension cord and plug the amp into it and run it to another socket in a different room. For me to remove the buzzing sound from my speakers I had to run some TV coax cable from my pre/pro FM tunner to my surge protectors coax connection. Do you have a grounding pin on your preamp?
    ht_addict
    • Tapesh
      • Oct 2003
      • 21
      A little background.
      I already have a separate HT setup with Denon AVR3300 + Polk RM7500. Perfect no problem.
      This is just recently that I got in to setting up a new separate setup for two channel listening. So the only inputs to PreAmp are from CD Player.
      Did try using Belkin surge protector, Monster Cable level 1 power strip, tried changing diff. out lets.
      I live in an apartment, just in case if that helps.
      Tapesh
        • 16478
        It sounds like a grounding issue to me. As mentioned above try running a power cord to another outlet and or try a "cheater" plug. If either of those work you have a ground issue that we need to deal with to remove the hum. The alternative to a humming amp is to simply teach it the words but try as I might they all seem to be tone deaf and don't respond well to my teachings so I'd suggest trying the first methods first
        • timetohunt
          Help with Audio Coax cables
          by timetohunt
          I am new to the audio hobby. Have about 12k worth of music but nothing of an audio system to speak of yet. So I am working on it. Here are a couple questions about the coax audio cables.
          #1. I realize that these are required in order to pass HT or surround information from a CD/DVD...
          05 February 2007, 10:58 Monday
        • xyzsurf
          First Post(long): Ideas, Questions, and the verge of Insanity!
          by xyzsurf
          Let me first say Hi! My name is Mike and I'm sure I'll be hanging around here quite often now as I get sucked even further into this monstrous money pit. After I got my first entry level system about 7 months ago, I've been getting deeper and deeper in. Now after having had some Dynaudio 52s at the...
          05 July 2005, 11:18 Tuesday
        • Joey_V
          Heard the RB1090 and RB1091 side by side...
          by Joey_V
          Today, I just got back from hearing the 1090 and 1091/1092 amps duke it out with the BW802D... side by side. I must say, I preferred the RB1090 by a good margin. I thought that the 1090 took better control of the 802D in ALL aspects, from the bass to the diamond tweeter. The 1090 had greater stage...
          31 March 2006, 22:52 Friday
        • AA6US
          Rb1080 trade-up to RB1090
          by AA6US
          I recently bought an RB1080. My speakers are 2.5 ohms, and I have to put a 200W non-inductive resistor in series with one side of the speaker cable to bring it up to 6.5 ohms, which the RB1080 handles just fine (It did NOT like 2 ohms and now I see in the specs the RB1080 works only down to 4 ohm, not...
          28 May 2005, 01:37 Saturday
        • Joey_V
          Rotel RB1070 vs Rotel RB1090 review
          by Joey_V
          I'm going to write a little bit about these 2 Rotel amps from my experience with both in my system at the same time.
          Setup:
          SqueezeBox3 -> Rotel RC1070 preamp -> Rotel RB1070/Rotel RB1090 -> Martin Logan Summits -> Joey's ears
          Build:
          The 1070 is...
          20 October 2006, 00:21 Friday
