It's not convenient to take the cover off and look. Where are the two transformers located?
Location of transformers on Rotel 1090 power amp
I could only find a picture of the old version, where the two transformers were side by side in the front of the unit. The newer design with the better speaker terminals has one transformer in the center front, one in the center rear. Both design have them under all the capacitors, so you still wouldn't see much pulling the cover.
Kevin D.- Bottom
