In need of advice for 1st pre/pro purchase please
  • BKSinAZ
    • Feb 2003
    • 107
    Before I ask my question, allow me to mention that for the last 3 years I've been using my YAMAHA rx-v2095 receiver only as a pre/pre for my Rotel 2095 amp. I've been waiting the the new rsp to come out and from what I understant, it should be out in the USA by the end of the year.
    Because no one has had the chance to demo the new rsp-1069, this is almost hypothetical.
    Does the new rsp-1069 appear to be better than the older rsp-1068?
    When I say better, I mean sound quality in movies and music.
    I ask this because right now I can get the 1068 for around 1500 + or - a couple of hundred, yet the new 1069 will be $2200
    Will the new 1069 be worth the extra cash?
  • june
    • 907
    Hello bksinaz,
    1st i can't comment on the 1069, but going from yamaha to rotel is the way i went. my yamaha rxv3000 did it's job for years. but went i was ready to go to separates, rotel rsp 1068 & rt-02 was the answer. for $1500 (processer & tuner) you will not be disappointed. their are lots of processors on the market, but rotel was the best bang for my buck.
    June
    • roscoe62
      RSP1069 and low bass issue (long....sorry!)
      by roscoe62
      Hi all,
      A few months ago I purchased a Rotel RSP1069 pre/pro to replace my aging Rotel RSP976. The main feature I wanted was the ability to process multi-channel PCM audio via HDMI. It took several months to get it integrated into my system, get the control side of things sorted out...
      18 February 2009, 02:19 Wednesday
    • Dmantis
      Ok, hows every bodies rsp1069 doing?
      by Dmantis
      What's up everyone???
      I'm killing it to upgrade my rsp1068. One final trip in here to get some updates on the rsp1069's progress. I have not read anything lately so I wanted to ask about sound updates....
      1)How is the audio and video working with Blue Ray and Hd dvd VIA...
      18 December 2007, 21:45 Tuesday
    • Ken49r
      RSP-1069 Bass Management
      by Ken49r
      I just purchased a JL Audio F110 sub and want to set this up correctly with my RSP-1069 and B&W 805s.
      Is it better to use the bass management from the RSP1069 or the separate controls on the F110?
      So far, on the RSP1069 I set crossover at 80 and sub level in...
      09 June 2009, 20:49 Tuesday
    • scanido
      Rotel RSP-1069 VS McIntosh MX119 Processors
      by scanido
      Hey All,
      Need advice from the trusty board. Currently I have a Rotel RSX-1057 and am using as my Processor powering my MAC MC205. With a budget of $3000 I can get either the RSP-1069 or a used MX119.
      I will be connecting the processor to my PS3 via HDMI for the RSP1069...
      30 April 2008, 18:43 Wednesday
    • Ross1069
      How to tell if the RSP1069 has the scaler bypass mod?
      by Ross1069
      Hi all,
      I'm getting ready to upgrade from my, now ancient, RSP976 to the RSP1069. I have a dealer willing to do a really good price on the 1069, but I'd like to know if there's an easy way to tell whether the unit has had the video scaler bypass modification done or not.
      14 August 2008, 04:13 Thursday
