RSX-972 Forgets Settings if Power Removed
  • lewb
    • Oct 2003
    • 8
    I have an RSX-972 that forgets all input/output settings if the wall power is taken away.
    Is there something like a 'bios' battery that I can check for to fix this ?
    TIA ;x(
  • Kevin D
    • 4601
    The 976 and up hold it in an eeprom chip that doesn't lose it's settings. Not sure on the 972. Might want to give Rotel a call on Monday.
    Kevin D.
    • Nuthed
      • Jan 2007
      • 151
      Everytime the power went out my 972 would lose the settings too. It was a real PITA. If you have digital inputs assigned, inputs named or whatever it was a hassle. My wife couldn't even get the DVD player sound to work after an outage. My solution:
      A Monster HT UPS 500.
      You need a battery back up. I needed one for my RP tv anyway.
      You know what seems funny though, I had the receiver in storage for almost 2 months while I was between homes, I don't think it lost the settings then. It seemed to happen only when the power goes out, whether it was in standby or powered on. Prior to having it in storage I used to turn the receiver completely off by the front panel button, could this have something to do with it?
      Main System
      RSX-972 driving center and surrounds
      RB980-BX driving mains
      Paradigm Monitor 9s V5
      Paradigm Monitor C-390 V5
      Paradigm Monitor Atoms V5
      SVS PB-12
      • lewb
        • Oct 2003
        • 8
        Yeah, I got a bunch of stuff like that set-up. I'm getting pretty good at entering the info now that I made a cheat sheet with all the settings.
        Only problem is that many of my names like dVd and dSS have letters towards the end of the alphabet. :evil:
        I sent an e-mail to Rotel tech support asking what to do. We'll see ..
        • Nuthed
          • Jan 2007
          • 151
          Heres what I got from Rotel today:
          There is a storage cap on the digital board that maintains the FM presets and the
          internal settings. This cap fails to maintain a charge after a period of time.
          We do have replacement storage caps to fix this problem.
          We can issue you a RI (Repair Invoice) for service. We will need to know
          your Name, Shipping Address and Telephone Number along with the Model, Serial Number and a detailed description of the problem. We will send you a RI Conformation with a shipping label (not pre-paid) attached. If you would like a RI please give us a call at the number listed below or E-Mail me all the required information.
          Best Regards;
          George Miller
          B&W Group USA
          Technical Support Specialist
          54 Concord Street
          North Reading Ma. 01864
          1-800-370-3741 Ext 236
          GMILLER@BWGROUPUSA.COM
          Main System
          SVS PB-12
          • lewb
            • Oct 2003
            • 8
            Thanks, I got the same message.
            • lewb
              • Oct 2003
              • 8
              Just a quick update:
              I sent my receiver off to Rotel. It came back today (after almost a month). It is repaired and they did the work for free.
              Let me say that again, they did the repair work for free on a piece of equipment that is close to 5 years old !
              Rotel rules ! :T
              • Gdbeck
                Rotel RSX-972 / RB980BX combo (review)
                by Gdbeck
                Great Budget Combo....
                I used to be a stero junkie, must have owned 25-30 different stereo systems always looking for that perfect sound. That was until I found Rotel and specifically the RB980BX poweramp (which goes ever so well with my Newform Research Ribbon speakers). This setup met all...
                12 March 2006, 15:13 Sunday
              • bigkid
                RSX972 - mains preouts to power amp
                by bigkid
                Hi all,
                I have a question on behalf of a friend. He has an RSX-972 integrated AV amp with pre-amp outputs (I think I have the model number right). He wants connect the pre-outs for the main left and right channels on the 972 to a good quality stereo power amp for a better quality 2 channel...
                29 March 2003, 01:55 Saturday
              • Ranger_Rick
                RSX-972 5.1 Analog Audio Input Problem
                by Ranger_Rick
                I have been the owner of a Rotel Surround Sound A/V Receiver Model RSX-972 for 5 years. I have used it with DVD, CD and laser disk players, and cable TV as sources and have driven a full set of surround speakers and a high definition, rear projection, large screen TV successfully with it, often at high...
                17 May 2007, 20:17 Thursday
              • bung99
                how great the difference 2ch Rsx972 to Rsp1068 as pre-amp
                by bung99
                Considering a 1068 instead of using my 972 as a per-amp. I have the RCD1072 (cd player) pluged in analog & the RMB 1095 as the power amp to my NS1000M Yamaha speakers for 2 ch with my sub set to cut in at the lowest setting on the sub. I do have a 5.1 setup but mostly play CDs & get into a...
                26 January 2006, 05:18 Thursday
              • paazel
                Crossover Settings Rotel RSX-972
                by paazel
                Hello:
                I have an Rotel RSX-972, B&W 602s2 (front), LCR-6s2 (center), 601s2 (surround), and a Velodyne SPL-1000 (sub).
                I have the speakers set to Large, and am wondering what frequency that crosses over at. I'm asking as to properly adjust the crossover frequency for my subwoofer....
                16 April 2007, 16:03 Monday
