RSX-1067 and Upgraded Power Cable
  • azrotel01
    • Aug 2007
    Hoping for some guidance and have not been able to find in of the posts here. How do I upgrade the power cable for my RSX-1067. All the upgraded power cables have the ground connector - whereas the Rotel does not. It there a specific company that makes cables/adapters?
    Any help would be much appreciated.
  • shadow 8
    • 153
    Why do you need to upgrade? The factory cable is shielded and works just fine.
    • hifiguymi
      • 1532
      If you want to experiment with different power cables, any of them that are a standard IEC on the receiver end will work. The third ground prong will do nothing and harm nothing.
      Eric
      • Russ L
        • 544
        I would invest in a quality power conditioner like the Rotel RLC-1040 before trying power cable upgrades. Or try both at the same time. The Line Conditioner will give you more bang for the buck. I found thats all I needed and gave me a very smooth sounding system with less distortion. A large difference. :sn Exotic power cables MAY have lowered the noise floor after much swapping of cables. A difference?:huh: Of course I did not demo any power cable over $150. Good listening. Regards, Russ
        Russ
        • Andrew M Ward
          • 717
          Agreed...
          the RLC-1040 performs measurable (can be seen on test equipment) improvements to the utility (wall power) no smoke and mirrors - 100% science and I find it to be an important element in any system, think of it as an essential piece of gear...
          8)
          • indiebands
            803Ds delivered - have to decide on cables soon (power cables for Monoblock amps)
            by indiebands
            My 803Ds were delivered on Tuesday and I have been having a good time during the burn in period (not sure neighbors can say the same). My local stereo guy has recommended speaker and interconnect cables which seem like a good fit to me. However, he's also installed a pair of fat power cables for each...
            10 April 2009, 17:10 Friday
          • Horacio
            Upgrading power cables on my Rotel Equipment?
            by Horacio
            I'm contemplating upgrading my system with new power cables and would like to know if you think/know if this would improve sound quality.
            I own a Rotel system: RCD-1072 CD player, RC-1070 pre amp, RB-1080 amp, with the power cables provided by Rotel, Nordost interconnects, B&W CM-4s,...
            13 August 2005, 18:33 Saturday
          • migliore
            Power cables, what are your thoughts?
            by migliore
            Please put yourself in one of three categories:
            a) never tried after market power cables
            b) tried them but didn't make a difference
            c) tried them and did make a difference
            If you tried some, which cables and what is/was your system?
            20 March 2001, 17:44 Tuesday
          • BlazeMaster
            Longer power cables..
            by BlazeMaster
            Hey members...
            I've moved to a new place and the room that I'm setting up my system has a different layout. I now have a much longer throw distance and therefore need longer DVI cables and power cables. I've seen alot of power or AC cables out there, is there a particular type that I should...
            10 September 2005, 20:38 Saturday
          • Aldo
            Classe AC power cables
            by Aldo
            Does anybody knows where can I get not so expensive but good AC SHORT (about 2 feet) AC power cables for CAM400 mono blocks?
            I need them for a custom installation and I need the to be short!
            Maybe LEX can help me?
            28 January 2008, 17:39 Monday
