Send Audio over Tape OUT output?
  • bokes
    • 32
    I have a sirius radio hooked up to my Rotel.
    I am using the TAPE IN analog connection.
    I want to send the audio to my computer so I can record programs.
    I tried hooking up analog cable runs from the TAPE OUT connection and I get no sound (?)
    I then tried to get sound from the video outputs and I couldn't.
    How do I send the audio out of the rotel to a record device?
  • Kevin D
    • 4601
    You have to set the REC-OUT to the input you want to record. Due to feedback issues, you can't send an input to the same output. IE, the source going to the TAPE-IN will never be available on the TAPE-OUT. You will have to use of of the video record outs.
    You should be able to hit the REC button on the front, then TAPE.
    Kevin D.
    • Bob_Collins
      Tape loop / record-out source select
      by Bob_Collins
      Ok guys, I have a question to pose. Are there any Home Theater receivers or processors out that include the venerable, old “tape loop” function? I’m referring to the ability on older stereo equipment to select a source for recording out to the tape outputs, but still allow you to choose to listen...
      29 May 2003, 12:20 Thursday
    • Jive Dadson
      RSP 1066 - tape loop?
      by Jive Dadson
      This feels like a dumb question, but after spending I-don't-know-how-long just trying to figure out how to adjust the left/right balance, maybe not.
      Is there a way to put an equalizer into a tape loop or external processor loop, and if so how?
      Do I select TAPE for LISTEN...
      17 December 2010, 09:24 Friday
    • STV_Keith
      Yamaha DSP-A1 DVD input vs. tape 2 monitor...
      by STV_Keith
      Hello. I recently acquired a Yamaha DSP-A1 to replace my aging DSP-A1000. The A1 has all the newer HT stuff that the A1000 didn't. I am using the digital coaxial from my DVD player for audio, and component video straight to the TV.
      I also use the Tape 1 record out to go to my equalizer,...
      27 September 2004, 23:24 Monday
    • Bob
      Who knows record values?
      by Bob
      I'm hoping someone here can help me determine the value of a record I found yesterday. I was helping out my mom by cleaning out her garage and found a box of records I must have left there almost 40 years ago and forgot. Fortunately I had the forsight to at least tape the box and wrap it in plastic...
      27 July 2006, 13:25 Thursday
      I Think I'm In Love. . .
      by David Meek
      or lust, or maybe it's just a bad case of upgrade-itus - but I want one of THESE!!!!!!!! :drool:
      It's Musical Fidelity's new kW500 integrated amp. Yowzah! 8O MSRP is 3,999 Pounds which is (today) US$7,090. It's a limited edition - only 500 will be built. It's a...
      03 September 2004, 12:38 Friday
