Are there any resets I can play with? no power whatsoever!!!
HELP!! RSP1098 will not power on
A couple of things you can check:
1) Check to see that the toggle switch in the rear is on.
2) Check the dip switches (used to upgrade firmware) in the rear near the middle, are set to the off position.
3) Check the power cord to ensure it's firmly seated and plug into a different electrical outlet.
Hopefully, it's one of these things that has posed an issue and not a power supply or board issue.
Just my quick thoughts, keep us posted.
Peace and blessings,
Azeke- Bottom
No, they wouldn't reset themselves.Originally posted by sysopthanks for the quick reply ...
I checked everything you said except for the dip switches. Would these somehow reset themselves.
Working fine then go to turn it on and nothing.
Perhaps you can provide a little more history to help improve trouble-shooting techniques.
Azeke- Bottom
by asacamWould someone please tell me where the DIP switches are on a RSX-1055. Thanks-
Channel: Club Rotel
by >>Angel<<Hi,
I recently bought the RSP1098 (next to the RMB1075) in combination with the RDV1060, what a nice combination this is
. However I do have some issues/questions:
- How can I enable color on the TFT display when DVD video is passed (via composite video) to the 1098?...-
Channel: Club Rotel
by sarsiI like to share some of recent experience with my new 3D TV setup with my current Rotel RSP1098/RMB1095 setup. I am hoping this information is useful for anyone with the same configuration out there that are interested to take the 3D plunge.
I had not been very active in the last couple...-
Channel: Club Rotel
by wa5655Hi, all.
I am ready to upgrade the power cord for my RSP1098. However, most after market cord has a 3 vertical pin IEC connector on the end goes into the RSP1098. The OEM cord only have vertical 2 pins. (not C7-rounded)
Any ideas where to find an adaptor for it? I have searched...-
Channel: Club Rotel
- Loading...
- No more items.
