Hello, I just signed up and have a question. My RSP 1068 has a recurring problem in that it will not accept controls from my RR1050 RC. The volume always seems to work but the other controls do not. I have tried reseting the remote with no success. It seems the only way to correct this is to unplug the 1068 from the wall for a few seconds, then it works for a while. Anybody else had this probem? Any thoughts? Thanks.
RSP 1068 Problem
Since it starts working after unplugging it, this probably won't apply. But I have to state it anyway.
For any functions besides volume and source, the remote needs to be in the audio mode. You you have to hit the upper left AUD button before the other functions work.
Now, I'm assuming you know that considering the power reset fixing it. I've seen bad IR receivers in the processors do similar things, so it might be that.
What type of TV do you have? A lot of plasma's produce stray IR signals that I've seen effect the units. If you do have a plasma, the next time it messes up turn the TV off and see if that corrects it.
Kevin D.- Bottom
Yes, I do know about the remote being in the audio mode(found out the hard way). My TV is a Sony Bravia XBR LCD 40". So that should be the cause. This is a sporadic problem. I think I am going to start taking notes on the specifics ( what works and what doesn't because it changes from time to time) and then talk to Rotel or my dealer about it.- Bottom
firmware maybe have you recently updated?
i am not sure can you reflash over top of an existing oneMain Linn Ninka
Center Linn AV5120
Rear Linn Ninka
Sub B&W ASW 650
Processor Rotel RSP-1570
Amp Rotel RMB-1075- Bottom
I have a similar "problem" with my 1068. It stops responding to remote commands. Before I found the "fix" I tried just about everything - switching off the main power switch, resetting the defaults, etc., until out of frustration I thumped it on the top with my fingers. And it worked... for a while. Now when it happens I walk across the room and lightly thump it top center, and it may work perfectly anywhere from a few hours to a week before I have to do it again. It's just a minor annoyance, and otherwise the unit sounds and performs great, so I've just been living with it. But I thought it was worth a mention.
My firmware is still v1.2.4 so maybe the firmware update will fix it when I get around to installing it.- Bottom
