Sound Quality [DVD vs. CD]
  • redwings99
    • Jan 2007
    • 8
    Hi.
    In general will you get better sound quality for music using a CD player (1072 for example) vs. a DVD player (Denon 2910). Thx.
  • Ted
    • 219
    Yes, you should get better sound quality from a dedicated CD player over that of a DVD player.
    Ted
    "I've gone to this high school for seven and a half years - I'm no dummy." - Better Off Dead opcorn:
    • thyname
      • 358
      I second that.
      • Iggurk
        • 114
        2910 wasn't a really good player for music.
        Even my 3910 (quite modded) sounds poor compared to my dedicated sacd player, and 3910 is far beyond 2910 for sound IMO.
        If you really want to enjoy audiophile sound go for high end cd/sacd player.
        • deke
          • 107
          Can anyone offer any technical insights into why this might be the case?
          • redwings99
            • Jan 2007
            • 8
            Thanks much.
            What are your opinions of the 1072?
            • wolfgang
              • 75
              None. Listen with your own ears again but with care this time. Don't simply believe everything printed in audio mags.
              • deke
                • 107
                Didn't mean to imply that a stat would suffice. I personally compared my old Rotel RCD-975 to my new (at the time) Denon 2910 DVD player and much preferred the old Rotel. This surprised me as I'd suspect that even a shitty component is better than a higher end one that's 5 years older.
                • cfrizz
                  • 51
                  I thought the same thing Deke! I found out differently when I compared my then RCD 855 with my much newer Pioneer universal player. My 855 stomped all over the Pioneer.
                  Cathy
                  Sunfire TGP III, Sunfire Cinema Grande 405wpc 5 channel Amplifier, :B Rotel RCD-1072 CDP, Onkyo TA2600 Tape Deck, Pioneer Elite 47-A DVD, Sony 32" XBR TV, Sony PS-454 Turntable, Polk RTA-8T Main Speakers, Boston 920 Center Channel, Boston PV600 Sub Woofer, Polk FXi-3 Surround Speakers
                  • peterS
                    • 1038
                    they are identical besides bass management as far as i know?
                    • jim777
                      • 831
                      Maybe that in a "cheaper" DVD design, the DAC will have only one clock for 48 or 96kHz sampling. Listening to a CD means that the player must do odd resampling of 44.1kHz audio to 48kHz.
                      The CD player will be optimized for 44.1 only, since there is no 48, 96 or 192 to support.
                      • voxy
                        • 113
                        Well if you compare the Rotel 1072 and Marantz DV9600, the Marantz wins hands down. I have both.
                        • ejuanpiman
                          • Nov 2006
                          • 100
                          well voxy, what do you think the rotel lacks that the marantz wins? , why do you like more the marantz than the rotel in other words.
                          • chinets
                            • 855
                            I would disagree with Voxy ,as I have both too. I find the Marantz DV 9600 with SACD and DVD-A exceptional ,but that is for Multichannel which the RCD 1072 does not have ( I mean the SCAD and DVD-A capabilities). However, In CD Redbook I find the RCD 1072 smoother and warmer than the Marantz. The Marantz don't get me wrong sounds fantastic for a Universal player/CD player ,but the Rotel 1072 has a better STEREO sound stage and more smooth to the ear. The Marantz is more clinical and has more detailed highs and maybe more musical to the ears, but fatigue sets in quick In Stereo mode compared to the 1072 also the DV 9600 lows are more boomier but that is in STEREO mode ONLY, because when it comes to Multichannel SACDS and DVD-A the Marantz wins hands down. To get Multichannel with the 1072 you have to have it in 5 Channel mode Analogue ,and even there the 1072 is better sounding and more warmer than the DV 9600 in 5 Channel. High Rez is another story, as the Marantz is the King of High Rez with SACD and DVD-A.
                            My 2 cents
                            Cheers
                            • redwings99
                              • Jan 2007
                              • 8
                              I'm running the 1072 in Bypass and really do like the sound. Perhaps I'm just hearing things but I do seem to have much more clarity than my Denon 2910.
                              • DL86
                                • 271
                                Well heres my experience of cd's played on: marantz dv6400 dvd player---> yamaha rx-v657 --> rotel rb-1090 vs shanling cd-t80 --> rotel rb-1090. The latter combination makes the first combination sound muffled and harsh in comparison, with the shanling it just add's layers of realism to the sound and you hear more. Its not a subtle difference its actually quite noticable.
                                Theres my 2 cents
                                • ejuanpiman
                                  • Nov 2006
                                  • 100
                                  i love my 1072...
                                  • NonSense
                                    • Nov 2003
                                    • 138
                                    Actually the 2910 and 3910 have different audio DAC's
                                    The 2910 uses the DSD-1791
                                    The 3910 uses the DSD-1796
                                    The 3910 was the real successor to the 2900 model. At the time, the DSD-1796 was boasted as Burr-Brown's top audio DAC. (that is why the 3910 is a favorite amoung tweekers) However, some still felt that BB's PCM1704 was still the best performer.
                                    There's more to a player than just the DAC, but the difference shows that the 2910 and 3910 were designed to have a different level of audio performance.
                                    Bruce
                                    • chinets
                                      • 855
                                      Yes, 1072 In Bypass mode sounds best !!!!! Better than DV 9600 In 2 channel IMHO !!
                                      • mpeak
                                        • 26
                                        RCD-1072 is still the winner here
                                        My friend has the Rotel RCD-1072 (so do I) and had the Shanling T80 and we spent one weekend going back and forth between the two on his RC-1090/RB-1090 and he kept the Rotel RCD-1072 and sold the Shanling, he was quite upset with the results because he had listen to another that said the Shanling was better. What may sound better to another, just may not to another. In this case, I too liked the Rotel RCD-1072 over-all much better! I DID NOT like how the Shanling softens the sound. Background detail and echos are easily heard on the Rotel RCD-1072 while the Shanling softens too much for my ears liking that it filters out some detail for the softer sound in those areas. If you like your sound a bit softened out, you'll probably like the Shanling, if you like to hear it in more detail, you will love the Rotel RCD-1072, yet the Rotel is still smooth.
                                        • loveatari
                                          denon dvd 2910 vs others vs rotel
                                          by loveatari
                                          hi,
                                          Im new to the forum and would like to get some opinons on dvd-a players. I just purchased the Denon dvd 2910 and wanted to know if there was something better in that price range, I got it for $550. A friend told me to check out the rotel dvd's, but Im not sure if that is a great product...
                                          08 April 2005, 12:12 Friday
                                          Review samsung DVD-HD1000
                                          by Lex
                                          Here's my "new" DVD player, the Samsung DVD-HD1000.
                                          This DVD player was really a surprise. I'd not heard of it, until accidentally finding one used on the net. Not knowing what it was, I went to the Samsung site to research it. What I saw was a beautiful player, that exuded...
                                          07 February 2004, 00:51 Saturday
                                          Photos of Samsung DVD-HD1000
                                          by Lex
                                          Here's my "new" DVD player, the Samsung DVD-HD1000 40 pounds of joy. It's actually slightly used, but showed no real signs of it. New used, we'll call it.
                                          reprint of specs from other post:
                                          That's a Samsung DVD-HD1000 DVD player, reputed to upconvert...
                                          11 January 2004, 22:54 Sunday
                                        • Martyn
                                          Denon DVD & Receiver decision
                                          by Martyn
                                          I'm heading towards 5.1 or 7.1 HT sound, but don't want to risk a drop in 2-channel audio quality over my present system (I run a Denon 3300 into a Linn integrated amp). I'm considering changing to a Denon DVD 2910 and AVR 3806 combination. Will the 2-channel audio quality decline? Would the Denon DVD...
                                          08 March 2006, 02:27 Wednesday
                                        • Cracking Oboe
                                          A Rotel mulit-format player? Why?
                                          by Cracking Oboe
                                          I was waiting for a Rotel multi-format player to come out. In the meantime, I thought I’d do some research. After spending months of listening to many available Muti-format players and stand alone DVD-A / SACD players, my wife and I came to the following conclusions:
                                          The Rotel’s...
                                          15 October 2004, 12:17 Friday
