I need help!
  • stacker45
    • Jan 2007
    • 4
    I need help!
    I am this close to upgrading my faithfull Yamaha RX-V 2200 and my Toshiba Sd-3800 for a Rotel RSX 1057 and a 1045 dvd player,i just need you guys to give me a few good reasons to upgade.
  • Kevin D
    • 4601
    What speakers are you running? Going from the bright Yamaha to the Rotel should be an unbelievable improvement, but your speakers will have an effect.
    Also, if you are interested in 5.1 DVDA discs, look for a used RDV-1050. The 1045 only supports 2ch playback of DVDA discs.
    Kevin D.
    • stacker45
      • Jan 2007
      • 4
      Kevin D.
      My speakers are Paradigm monitor series,and i listen mostly in stereo and often throught my headphones Grado gs-1000
      • apodaca
        • 63
        I dont think the Rotel has a headphone jack (The only flaw in their units and I dont understand why it is so). As for Yamaha sound - their gear has always sounded as if they put emphasis on the high frequencies and it can be distracting with many recordings out there especially the high number of already bright Dolby Digital and music CDs out there. This all depends on the type of speakers you have however.
        Feature and quality the Yamaha brand is good but their 'signature' sound is too bright for me. Outlaw Audio gear is n the exact opposite side of the specrum being dark, dull and lifeless. Rotel is just right for me in my system. I forgot to add that I sampled the monitors bookshelfs last month with Rotel gear and they sounded very good and actually prefered the sound over the 600 series B&Ws due to the sibilance I heard (I am considering a pair for a bedroom 2 channel system given thei are being phased out for the newer versions).
        • fordster
          RDV1060 DVDA Problem
          by fordster
          I've had my RDV1060 for a few weeks now and finally got round to buying a DVD Audio (Under Rug Swept - Alanis Morrisette). When I insert the disc the player picks up that it is a DVDA and shows 96-24MLP on the display. However, that's about all that happens beyond a bit of clicking. The timer eventually...
          28 March 2005, 14:14 Monday
        • Mike Hayes
          DVDA/SACD Connections to 1066
          by Mike Hayes
          I am considering purchasing a Pioneer 563A ($180) universal player to replace my Toshiba SD5700. I am currently using just the digital connection (not using the 5 analog cables for DVDA). This will be my first experience with DVDA/SACD in conjunction with my 1066 so please bear with me.
          03 August 2003, 09:53 Sunday
        • Danbry39
          Help on setting up for DVDA
          by Danbry39
          Just bought my first DVDA, Vivaldi's Four Seasons, and need to know how to set up the Rotel 1066. Denon 1600 DVD player to output DVDA. Right now, I've placed the disc in the 1600 and sound seems to come out of all speakers after I pushed the Multi Imput button on the Rotel's front panel. The display...
          16 March 2003, 15:58 Sunday
        • sskim
          RDV 1045, RDV 1060 or RDV 1080 ???
          by sskim
          I need advice on Rotel DVD player. If the price was non issue, which is the better player, RDV 1080, RDV 1060 or RDV 1045, and can you tell me why? I'll be pairing up one of these with RSX 1057 and the display is Pioneer PDP-5070. One last bit of note is that I will be using it for both DVD watching...
          14 February 2008, 09:39 Thursday
        • Kevin D
          RDV-1060 update to fix DVDA, does exist!
          by Kevin D
          Just to let you know, Mike at Rotel definately knows about the DVDA problem that reverts the 1060 to SCART mode, and they have an update. I know some people got the update, while others were getting the run-around..
          They were pretty serious about saying you could really mess up your...
          21 July 2004, 17:41 Wednesday
