Setting UP Control4 automation/dist audio. Downside to using Rotel 1077 as amp?
  • stewfoo
    • 275
    I am in the process of finalizing my whole house automation/audio distribution system. I purchased the Rotel 1077 to power my B&W CCm80 in-ceiling and B&W WM6 outdoor speakers. Any downside to using this amp in this application beside cost? I want to push the system to its limits..
    Stew
  • Kevin D
    • 4601
    No downsides at all, but I would recommend getting something to to handle bass/treble/loudness controls. You can throw all the power in the world and still not like it if it's thin or muted sounding.
    Kevin D.
    • stewfoo
      • 275
      The c4 amp has all of that. But, I am hearing some disappointing posts about its performance. I would rather get a great amp like the 1077 and add EQ later..
      Stew
      • IntegrateMe
        • 73
        Stew-
        Fantastic idea!!
        We typicall use either Crestron or Sonance amps for audio distribution (frequently with B&W speakers) and in a current installation we were forced to utilize 8 RMB-1077's since the owner's space and heat constraints were substantial.
        However, I would have to echo Kevin's sentiments about a preamp/DSP being used in the chain. In our instance we use a Crestron PAD8A, but I'm not too familir with the C4 equivalent.
        Good Luck!
        Barry
        • stewfoo
          • 275
          Their equivalent is an audio matrix switch. But, it does not have control over tone, just volume. I will see how it goes and maybe add an EQ later.
          Thanks for the thoughts IntegrateMe!!
          Stew
          • stewfoo
            • 275
            Just finalized my purchase. I decided to go with two 1077's for my in ceiling and outdor speakers. This house should rock. I will keep you all informed. Thanks for the input!
            Stew
            Stew
