Good evening.(In my time zone anyway)
I'm having a bit of trouble with my Rotel RA 930AX Amplifier.
When I connect my left speaker to the left channel in both the direct and remote binding posts, I get no sound, except when I turn it up near to the max, where it is very distorted and crackly.
However, it is not a problem with my speakers, as I connected both them to the right direct and remote channels. However, with loads of my albums requiring you to have both channels functioning to hear the sound, it's rather irksome to have two right channel speakers.
Will it be a prroblem with dirt and dust in the amp? Should I buy some cans of contact cleaner and compressed air to alleviate the problem? If not, then what will fix this problem.
Thanks In Advance.
Thanks In Advance.
