Rotel 1040 will not play DVD-R - any help?
  • mikej
    • 27
    I have tried to play DVD-r on my rotel 1040, it was recorded from a Magnavox recorder ( MRV700VR). HAs anyone had this problem, before?
    mike
  • Kevin D
    • 4601
    I had no problem playing DVD-R's on my 1040. Sounds like something is wrong with the burner, maybe it doesn't automatically finalize the disc?
    Kevin D.
    • mitch57
      • 429
      Disks won't play in a standard DVD player until they have been finalized. That would be the first thing I would check.
      Mitch
      :stupidpc:
      • mikej
        • 27
        It states finalized
        It states finaiized, maybe i have to try it again
        • JOY DIVISION
          • 152
          You have to burn from your PC, not from a Recorder, the media on these are ussually slower than the ones you burn on your PC. Try getting Ridata or Taiyu Yudens and Verbatims and that should solved your problem. Here's a DVD media that will give your Rotel DVD players a problem eg. TDK- they skip and freeze, Pro-Disc is another bad media for Rotel. There are cheap ones that certainly work good, but those 2 stay away.
          • Boombox
            • 203
            tested your theory JOY DIVISION....TDK works just fine on my 1040; yep - finalized it should be...yes, try it again...
            Regards :T,
            Boom....a.k.a...."The Box"
            • mikej
              • 27
              I tried again and the dvdr dosen't play, but plays on a $150 dvd player. In fact, the dvdr plays on all the dvd players in my home, except the Rotel, I think I will return it for a differnet one. It doesn't make sense.
              • mikej
                • 27
                Dear Joy and Boombox,
                What are you using to burn the DVD-R?
                mike
                • mikej
                  $500 1040 vs $150 dvd player, which plays a dvd-R? you will be surprised.
                  by mikej
                  I have a Rotel 1040, I tried to play a recorded home movie on DVD-R (finalized) and it dosen't play, in fact, it can't read it. But to my surprise, it plays on a $150 dvd player. In fact, the DVD-R plays on all the dvd players in my home, except the Rotel, I think I will return it for a differnet one....
                  12 February 2006, 14:19 Sunday
                • ICEMAN70
                  My Review on the RLC-1040.
                  by ICEMAN70
                  I just finished hooking up everything to the new RLC-1040 conditioner. The first RLC-1040 i had was Faulty so got it replaced by another one which works perfect so far.
                  I listened to some music today from my RDV-1040 and it sounded more clear than ever when hooked up to the RLC-1040....
                  14 July 2006, 13:46 Friday
                • Club1820
                  Help w/speaker thump + RLC 1040
                  by Club1820
                  I need some help. Hoping someone has an idea as to what is going on.
                  I have the RLC-1040 with everything connected to it. 1095, 1068, 1060, & 1055 cd changer + M&K Sub. All units are connected to the appropriate input on the 1040.
                  I power up the 1040, everything...
                  18 February 2007, 20:28 Sunday
                • bryandaws
                  Rotel RDV-1040 Question
                  by bryandaws
                  Hey guys,
                  I just purcahsed a used RDV-1040 and I was suprised to fine that the rear panel jacks are not gold plated. Does anyone know if the jacks on any of the 1040's were ever gold plated or was it just on the 1050 or 1060. I could have sworn it was supposed to be plated. Since they...
                  10 February 2006, 10:45 Friday
                • Club1820
                  RLC-1040 - Error:Failed!
                  by Club1820
                  So today the mrs & kids were out of the house and I had some time to really crank my system for maybe the 3rd time since I've set it up. So I am "testing" it out to see how really loud it can go. The other couple of times I've only hit maybe 75 on the 1068 volume.
                  So...
                  11 March 2007, 01:50 Sunday
