Leave power on okay?
  • orangebull
    • 16
    Does it do any harm to the units (RSP-1098, RMB-1075, RB-1090) to leave the power on most of the time even when not in use?
    I have read that with some electronic componets the turning on/off (temperature changes) do more harm than leaving them on all the time.
    Recommendations?
    thanks, OB
  • orangebull
    • 16
    Anyone????????
    Someone out there must have an opinion about leaving Rotel 1098, RB1075 and a RB-1090 on all the time vs turning if off and back on once or twice a day.
    thanks, OB
    • Aussie Geoff
      • Oct 2003
      • 1914
      Lots of older threads on this.. Bottom line it is fine to leave them on all the time... I do with my amps as they sound better that way to me... The idle current draw is quite low...
      Geoff
      • Azeke
        • Mar 2003
        • 2123
        OB,
        I leave my RB-1080 powered on, due to fuse issues.
        The 1098 I leave in standby mode.
        The 1095 via 12v trigger.
        As Geoff stated there are plenty of threads in reference to this issue, try this one:
        Leaving on Amps
        Best regards,
        Azeke
        • orangebull
          • 16
          thanks
          appreciate the info.
          • Azeke
            • Mar 2003
            • 2123
            You're welcome.
            Azeke
            • dan87951
              • 379
              Wow im curious what you guys pay per month in electric bills for those that leave those monster amps on. I always shut all my electronics off (except computer) after I'm done with them. I noticed a rise in my electric bill with the RMB-1075 over my Harman amp, so I definitely shut it off the millisecond after im dont listening.
              dan87951
              audio guru
              • benny
                • 112
                If you're not playing the system, it takes very little power to light a few LEDs and the caps stay "charged up" so they're not really pulling juice either. If you want your gear to sound "showroom" quality, leave it on. Never noticed my electric bill jumping up at all.... -L8...
                • Stockinv
                  Leave On or Turn Off
                  by Stockinv
                  A just installed a new HT with B&W speakers and McIntosh 500w amps.
                  I'm listening to music in the morning and perhaps in the early afternoon and then at night. I'm constantly turning the system on and off. Is this harmful?
                  Should I just leave it on all day and turn it off at night?...
                  30 July 2005, 14:01 Saturday
                • Joey_V
                  Heard the RB1090 and RB1091 side by side...
                  by Joey_V
                  Today, I just got back from hearing the 1090 and 1091/1092 amps duke it out with the BW802D... side by side. I must say, I preferred the RB1090 by a good margin. I thought that the 1090 took better control of the 802D in ALL aspects, from the bass to the diamond tweeter. The 1090 had greater stage...
                  31 March 2006, 22:52 Friday
                • AA6US
                  Rb1080 trade-up to RB1090
                  by AA6US
                  I recently bought an RB1080. My speakers are 2.5 ohms, and I have to put a 200W non-inductive resistor in series with one side of the speaker cable to bring it up to 6.5 ohms, which the RB1080 handles just fine (It did NOT like 2 ohms and now I see in the specs the RB1080 works only down to 4 ohm, not...
                  28 May 2005, 01:37 Saturday
                • Joey_V
                  Rotel RB1070 vs Rotel RB1090 review
                  by Joey_V
                  I'm going to write a little bit about these 2 Rotel amps from my experience with both in my system at the same time.
                  Setup:
                  SqueezeBox3 -> Rotel RC1070 preamp -> Rotel RB1070/Rotel RB1090 -> Martin Logan Summits -> Joey's ears
                  Build:
                  The 1070 is...
                  20 October 2006, 00:21 Friday
                • carlsen
                  rmb1095 &rb1090 troubleshooting query
                  by carlsen
                  I've just assembled a system, consisting of using a denon 3805, running preouts to an rb1090 and a rmb1095 ( unbalanced).
                  I am only getting weak sound out of the main right and left front but nothing out of the other five speakers which are connected to the Rmb1095.
                  I read...
                  11 March 2008, 20:04 Tuesday
