I purchased a Rotel 1067 at Christmas 04 and I need some assistance and/or your expertise. I think I have a bit of a problem. I'm using the Rotel with Definitive Tech speakers (7.1 DT2002's). After the unit has been on for a few hours its starts with a crackle (for lack of a better term) in one of the side speakers and progresses from there. Worst I have heard it get is a loud crackle, hum etc. from all seven speakers. When you shut the unit off using the main power switch on the back of the unit - it goes away. couple of other smaller issues - i hear a constant hum when there is no sound signal going through the speakers. tends to be drowned out when watching a movie or satellite. Secondly, evrey once in awhile when you switch the video (on the rotel) from DVD to Sat or Sat to XBOX, etc. you don't get a picture. If you do it again, then you get the picture. Hope this makes sense. Any advice would be appreciated! Thanks!
Rotel 1067 Need Help!
by hamiltongFYI.. Software upgrades now available
RSP 1098:
V3.1.1 to V3.1.4 - Fixed an intermittent problem of units locking into “Standby” mode until the rear panel power toggle was engaged. - Improved digital input sensing and format detection. This improvement fixes any problems...-
Channel: Club Rotel
by rotelnyc2Hey all!
I'm a first time Rotel owner, been eyeing the RSX since the introduction of the 1065. First off, I did find a good amount of info on the hiss/pop issue amongst the threads, but didn't find much info on my questions and issues specifically so I decided to start a new thread,...-
Channel: Club Rotel
by SDSmithI recently purchased a used 1067. Recently it has started to intermitently crackle at times. Almost sounds like the static you hear on a bad phone line. The noise seems to occur at random times and I can hear through all my speakers. If it begins having one of its noise 'episodes' and I switch...-
Channel: Club Rotel
by KAPWhile I await the arrival of the RSX-1067 that is supposed to not have the crackling/popping issue, I have a couple other concerns that hopefully you guys can address:
When the Volume is at any level higher than "0", there is a distinct Humm, coming from all 5 speakers. This...-
Channel: Club Rotel
by JBallI set up my gear last night a fired it up. I bought the 1067 and the 1080 to bi-amp the fronts. I bought the Nautilus 803's. Inital thoughts, they sound much better than in the store. In the store they were actually too bright and wasn't blown away, i think the room was poor too. I bought them...-
Channel: Club Rotel
- Loading...
- No more items.
