2nd Rotel 1095 Amp issues! Need help!!
  • spkerguy
    • 51
    Someone please help! I love my 1095 amp. Good clean power. The only issue is every now and then I get a very audible (I can hear it from my couch) hum coming from the amp. Happens at all different times and then continues making the noise till I power down. This is the second new amp I have received from Rotel with the same problem. Is it the amp or just bad luck?
    Ken
  • Andrew M Ward
    • 717
    describe the Humm, or is it a hiss or a bzzzz
    if it's a developing humm, as in the amps fine for a few weeks then starts humming you're looking at electrical issues (possibly)
    1095 amps don't just randomly hummm, or at least i havn't seen a tendency for this.
    just my 2 cents
    • spkerguy
      • 51
      thanks. It could be a grounding issue. I have everything plugged in to a panamax 5500 Line conditioner. I'm wondering if that could be the problem. I'll go home and listen to it tonight and maybe I'll be able to describe it better
      • NewBuyer
        • 122
        Is the hum coming from within the amplifier chassis itself, as in from the amplifier's internal transformer?
        Or is it a hum that you hear from the speakers?
        • Azeke
          • Mar 2003
          • 2123
          Disconnect your cable connection, it is usually the culprit.
          Azeke
          • Mark_C.
            • Jan 2003
            • 386
            Possibly a grounding issue involving cable television connection or satellite connection. Do a search here for "amplifier hum.''
            • mitch57
              • 429
              I have the same issue. I purchashed a new Parasound Halo A51 and it buzzes as well. Both the Rotel and the Parasound exhibit no buzzing when they are connected at the dealer. I have determined that it is an electrical power issue coming into my house.
              The buzz is intermittent and varies in intensity with no measurable consistency concerning time of day or any other paremeter.
              It's so frustrating it's down right depressing!
              Mitch
              :stupidpc:
              • Andrew M Ward
                • 717
                Gentlemen Electricty is a theory and a science
                Electricity does all sorts of anomaly behavioral stuff. the ingredients are endless and non-sesical. The Rotel amp is quiet as a mouse at the dealer, the Halco was perfect at the store but now buzzes at your house?
                Go Figure?
                It's not you!
                it's the master feed coming in through your main feed breaker box. There are so many things to try. I tried almost everything, then my friend brought over this PS audio thing. A small-ish box that he said his electrical engineering degree would never defend to the level that the manufactured defended it to!
                I love controversy, so I tried it and my video problems stopped plus I swear I heard a sonic noise floor drop, but that might be "psychological mumbo jumbo" which I tend to be subject to.
                Good luck with the science of electricity, but I’ll tell you, the art of electricity might save you.
                Just my 2 cents
                Andrew M ward
                • mitch57
                  • 429
                  Go Figure?
                  It's not you!
                  Just my 2 cents
                  Andrew M ward
                  Andrew,
                  What do you suggest I try? What and how much was this "PS Audio" thing you tried? Does it require an electrician to install it? I'm thinking about calling the power company to see if they can shed any light on the subject.
                  Mitch
                  :stupidpc:
                  • chinets
                    • 855
                    I have ordered the 1095 Amp. and it will arrive shortly. I have currently the 1065 driving 803/804 and I have humming sounds from the 1065 when it gets hot, as it is pushing to drive these Power hungry 803/804 ,and yes I found that the Fan turns on in the Amp. every so often to cool the 1065 down..Could that be your problem with 1095...please keep me posted I am curious,as the 1065 is driving me crazy!!!!!!!!!!!
                    • Mark_C.
                      • Jan 2003
                      • 386
                      This isn't the first time this issue has come up. Please search for your answers.
                      http://www.htguide.com/forum/showthread.php4?t=9140&highlight=amplifier+ground+ loop
                      http://www.htguide.com/forum/showthread.php4?t=11482&highlight=amplifier+ground +loop
                      • chinets
                        • 855
                        Sorry clicked on your threads above and it doesn't open. We are all curious here!!!!
                          1095 does not have any fans, though it's not a bad idea to make two fans on top of the 1095 to help cool it. That's what I did and yesterday during the warm weather I was listening to a lot of music pretty loud (comfortably loud), when I stopped and there was nothing playing I actually heard the fans moving air. So they increased their speed/airflow as the am got hotter (since it was already a hot day it didn't take much). After about 2 minutes of nothing going through the amp, but the amp on, the fans slowed down to being completely quiet. Thermal technology is cool. ha ha
                          More often than not though the buzzing/hum from the Rotel amps is due to interference of the cable line, you pop that out and a lot of people it goes away. You can put a ground loop filter on the cable line and that tends to fix it.
                          • will1066
                            • 660
                            Originally posted by mitch57
                            Andrew,
                            PS Audio Ultimate Outlet: http://www.audioadvisor.com/store/pr...sp?sku=PSAUO15
                            Reduced my system noise floor but NOT cheap.
                            If it turns out to be the cable, try this: http://www.jensen-transformers.com/datashts/vrd1ff.pdf
                            When I had my RB-1080, it wreaked havoc with my cable TV. The Jensen ground isolator snuffed it.
                            • ds22030
                              • 109
                              Also try connecting a chassis common ground between your amp, preamp, and source......addresses buzzz, esp. if only one component is grounded....
                              • hired goon
                                1 x RMB-1095 vs 3 x RB-1080?
                                by hired goon
                                G'day,
                                I've currently got an RMB-1095 5x200w amp, about 2 weeks old. For a few hundred dollars, I can trade this in to get 3 x RB-1080 2x200w amps.
                                I'm wondering about the advantages and disadvantages of such a move.
                                This is what I've come up with:
                                15 November 2004, 20:31 Monday
                              • hired goon
                                RSP-1066+RMB-1095, or RSP-1068+RMB-1075?
                                by hired goon
                                G'day,
                                I can get the following combinations for the same price:
                                (a) RSP-1066 AV pre/pro + RMB-1095 5x200 amp; or
                                (b) RSP-1068 AV pre/pro + RMB-1075 5x130w amp
                                The ideal combination would be the RSP-1068 + RSP-1095, but that's beyond my budget for...
                                02 September 2004, 06:22 Thursday
                              • jazznsoccer
                                Rotel 1095 Amps & B&W802 = biamping make a difference?
                                by jazznsoccer
                                Hi All,
                                I demo'd B&W speakers and settled on the 802's (higher up was beyond my point of pain for speakers). I really liked the 802's over the 803. Alll tests were done using the Rotel RMB-1095.
                                I've heard that most people would suggest getting a better amp, but there...
                                30 April 2004, 23:36 Friday
                              • jlee
                                B&W N804's - looking for best amp to match
                                by jlee
                                Hello. I'm new to the forum. I read the rules and how we need to stay specific to B&W speakers and not stray to talk about amps, preamps, sources, etc. This post is about which amp would go well with B&W speakers, so hopefully it qualifies. I see no other better forum to post it in than in a...
                                29 August 2004, 02:21 Sunday
                              • thezone
                                RMB-1095 XLR & RCA inputs
                                by thezone
                                Can someone please help. If I connect both the rca and xlr inputs on the above amp at the same time how does the unit switch between the two if it recevies a signal from both as there is no switch?
                                Is this an unwise move? I am trying to fix my no ht bypass on my stereo...
                                14 March 2009, 01:22 Saturday
