Fans Fans Fans
  • Woo Wooooo
    • 177
    I used a Dremel with a round sandpaper tool once the hole was cut.
    I really don't think it's to high the ceiling in this room is onlt 8' tall i think the picture give the illusion of a taller ceiling. If you think it's still is too high what height would you recommend? The CM6's are on spikes :P
    Thanks for the input.... :B
    • jim777
      • 831
      Maybe your room wouldn't look as nice, but it could sound better if the surrounds were not higher than the center channel. In a perfect world, all the tweeters would be aligned at the same height (hard to do with a screen..). That way sources panned from a place to another will stay at the same "height" (the panning will then be more smooth). But for movies (with mostly "ambiance" in the rear channels) I guess that your current setup is very OK.
      But let's say that we are getting off topic about your fans
      Have fun anyway!
        Wooo Woooo, I agree looks really good. I agree with everyone if you bring them down to ear level...it will sound better (tweeter at ear level). In that case stands might work better for you though.
        Anyways, the fans look good and I'm sure it keeps those boys cool! Is there one behind the 1098?
        • Woo Wooooo
          • 177
          I would lower them but there is not allot of room getting around the theater chairs, you'd knock youself out trying :Z it was the lesser of the two evils I could angle them down 7 degrees where they are aimed but not sure plus the CM2's weigh a bit though
          there is no fan behind the 1098 because of depth with all the cables but the back panel is cut just a bit smaller than the size of the 1098 you just can't see it.. I'll will post a picture when i get home and you'll see what I mean.
          Thanks PewterTA :B
          • thyname
            • 358
            Thanks to you guys I have a lot better idea what to do in my new town home I'll purchase in a year (cross the fingers please). I am aiming for one with unfinished basement... you know what I mean...
            • Dallasdave
              • 28
              Fourth Picture:
              I jumpered the Power On Pin and a Ground pin with a wire and taped up the connector. I also have rubber boots on the 4 pin power connectors (not shown).
              PewterTA - Need soom help on this step of the instructions, can't find the right comb to jumper the power supply always on.
              • Dallasdave
                • 28
                Got it, jump the green and black. Works!!!!
                • Kens1
                  • 191
                  Yeah - very nice set up Woo Woooo. Very clean.
                  • ajpoe
                    • 439
                    This is what I did if anyone wants something really simple... I got a universal adaptor like this from parts express really cheap. I took a simple cooler master 80 mm fan and installed it into the back top of my audio cabinet (blowing out) b/c it gets hot in there. I just took the red form the fan and stripped the end and stuck it inside the 2.1mm coaxial connector, stripped the black and wrapped it around the outside of the plug and used electric tape to make all the connections snug. Now I can use the switch on the AC plug to determine how fast I want it to go via the voltage selector and even turn if off if I want. Or, if you have switched outlets, you could plug it into something like that as well. I think I had to switch the polarity, but it was really simple and cheap.
                    AJPoe - - Growing old is inevitable, growing up is optional!
                    • Stevebez
                      • Oct 2003
                      • 458
                      OK ... been stuffing around with fans in my cabinet now for too long. Found a very handy but pricy PC fan controller called Fan-O-Matic for PC use primarily, but seems can be "modified" for our purposes.
                      The unit is software configurable via serial cable (overkill ???) with temp sensors and so on... size is designed for a 5.25" computer bay , but electronics are perhaps an inch deep at the most - but with a bundle of wiring.
                      Handles 4 fans (or fan zones) with up to 12w output per zone - so you can have a couple of fans running in parallel and also has 8 temp sensors which are assignable to any of the 4 fan zones - have not quite figured out why they need 8 sensors for 4 fan zones but anyway.
                      Its not a pwm regulated voltage change but analogue so none of the "sticking" fan problems you get with pwm power regulation.
                      I finally want to get this cooling of my kit sorted once and for all ... My cabinet is now so full I can't even get my hands in!!!!
                      Will take time to sort out - time, wife and child permitting ... and will let you know how it pans out.
                      Rgds Steve.
                      • Woo Wooooo
                        • 177
                        Hey Ajpoe that is basically what I did. I bought a regulated adapter and cut the end off of it and hard wired the fans all together. It is working out very well.
                        Thanks to everyone!!!! ;x(
                        • Dotay
                          DIY variable speed quiet fan kit
                          by Dotay
                          When I was at DarrenE's house for our subwoofer test he showed me a variable speed fan he bought on ebay. I'd like to try and Klone :B this kit and I think it might bennefit those of us who are using pro-amps to power subs and the like to make the process public. The problem is I don't know exactly...
                          22 March 2006, 11:17 Wednesday
                        • thyname
                          RB-1080 or RB-1070 power amp to purchase?
                          by thyname
                          Hi guys: As I am thinking more and more to upgrading to separates, I came to a question of whether should I consider a 2 Ch RB 1080 or RB-1070. I initially thought of just purchasing 1070 as it is USD 300 cheaper and I think 130 W per channel is more than enough. However, I know that 200 per channel...
                          28 April 2005, 10:31 Thursday
                        • AndrewM
                          Speed...it's what's for dinner
                          by AndrewM
                          Well after about 3 years I've finally upgraded the ol' rig to something a little more fitting for todays needs. I wasn't really feeling the need quite as bad as in years past, but the bug bit me and it was time. So I'm not the proud owner of a new AMD 64-3200 system which has replaced the ol' trusty...
                          17 May 2004, 08:25 Monday
                        • spiffnme
                          Energy Veritas 2.2 vs Axiom M60ti
                          by spiffnme
                          The usual disclaimer applies...not scientific, yadda, yadda, yadda. (Though we did have a switcher to make changes immediately, and volume levels were controlled)
                          OK...many of you know I've been demo'ing new speakers for awhile now. I even went so far as to buy a Radio Shack 4 speaker...
                          10 July 2003, 12:14 Thursday
                          120 Hz Refresh Rate technology
                          So when I first heard people talking about the 120 Hz refresh frame rate technology a while ago, I didn't put a lot of stock in it. Lots of new technologies come up, and many of them make small gains.
                          What the refresh frame rate does is say how often the display updates its picture....
                          09 October 2007, 01:05 Tuesday
