I am having a hard time getting the latest eprom upgrade done using the Rotel flash up software. I download and unzip the eprom file from the Rotel web site, install the flash up program and use romupdate4.bin file, it keep getting me an error "device not response, check comm. port". I called Rotel tech support, they told me to reboot the RSP1068, but it still dont work. I used the same pc and com port and successfully get the firmware upgrade this morning. I am pretty sure is not my com cable nor my PC setup. Anyone out there have any clues? Also, after the firmware upgrade, there is a new option to key in the default password before you could save your config file, the default password is "0000" which is not documented in the Rotel instruction. I try to called Rotel again, but just got their voice mail. So far, I am not too impress with the Rotel tech. support, but I will try again. Appreciate anyone out who had successfully ugraded the RSP1068 eprom software can give me some help!! Thanks!!
RSP 1068 eprom upgrade Problem
Originally posted by RaphieIs your 1068 "ON" IE Playing? it needs to be "ON" in order to be recognized by the PC. also note that when you see the code, your ROM upgrade was succesful. So is your question about the rom or flash update?- Bottom
If you used the cable that came with the 1068 and you had the 1068 ON AND didn't touch the dip switches, then the only thing i can imagine is that you selected the wrong COM port in the flash program (you can either choose com1, com2, com3, or com4 dpending on how many coms are in your PC)- Bottom
Originally posted by RaphieIf you used the cable that came with the 1068 and you had the 1068 ON AND didn't touch the dip switches, then the only thing i can imagine is that you selected the wrong COM port in the flash program (you can either choose com1, com2, com3, or com4 dpending on how many coms are in your PC)- Bottom
Just to make sure thaqt i understand, your Rotel cable is RJ45 > DB9, this cable is connected with an db9 > USB converter on the USB port of the PC?
1. For MTTY you need to pull both dipswitches, turn the ystem unit on with the back button and your MTTY program should display the Firmware remote menu. (seemed that you managed to do this)
2. For Flashup, just unzip to any dir, run the install, configure with addresses with the instructions, leave the dipswitches in normal operating mode and just load away.- Bottom
Raphie, yes and yes to you're questions. I too am experiencing the same as wywong. Using XP home edition, belkin usb to 232 convertor. I have used a couple of different flash utilities with the same configuration in the past and it worked fine. I had backed off on the firmware version and tried that, no go. When I get home from work this morning I may try a different utility to see if one may work. I had noticed when backing off on th code revision it had said rom4 in one of the strings, could we be there allready? Raphie, can you get it to connect now that you are @ rom4? This would confirm or deny that assumption.- Bottom
Yes i can still connect (but i am using a "real" comport) which got me thinking some USB converter convert into a "Null Modem" port ths means that your cable is wired to the PC as a cross serial cable. "nd bugger might be that MTTY needs a dedicated interupt assigned to your serial port (no shared interupt as with USB) this might explain the fluctuations in your connections. So please see if you can assign a hardware interupt to your USB port, or find a PC with a "real" Serial DB9 port on it.- Bottom
when you say you use the romupdate4.bin file is that to say you've also installed 1,2 and 3 before 4?- Bottom
Originally posted by Andrew Prattwhen you say you use the romupdate4.bin file is that to say you've also installed 1,2 and 3 before 4?- Bottom
It's certainly conceivable that a widespread terminal program like MTTY wouldn't have a problem with a USB-9pin, but a limited distribution flashrom program would.
I would try a different adapter or someone with a built in port.
Kevin D.- Bottom
When I was doing the flash update, I followed the instructions and one thing that was not documented was when it say "Turn the unit on" it means turn the switch at the back then on the front. When I turned the switch at the back only I got nowhere, I tried it again and this time turned both switches on, and it worked.
When doing the software upgrade you only need to turn the switch on at the back. Also reset the unit when done with the upgrade for the changes to take effect.
Just for reference my unit is the RSX-1056. Hope this helps.
Don- Bottom
Andrew, I was referencing a different device I had dealt with in the past which was "flashable" and with a few different utilities I was able to connect and was off to the races. I have not done anything with Rotel's in the past.
I have an old ctx laptop somewhere, when I find it I will try the 232 port on it. Thanks guys.- Bottom
I think ya nailed it Raphie, I rounded up my ctx ,windows 95, 166 mmx, rs232 ports, away she went. I knew there was a reason I didn't sell it at a garage sale or throw it away, Thanks, Bob- Bottom
Originally posted by soundhoundI think ya nailed it Raphie, I rounded up my ctx ,windows 95, 166 mmx, rs232 ports, away she went. I knew there was a reason I didn't sell it at a garage sale or throw it away, Thanks, Bob- Bottom
wywong, correct. I suspect our problems were one in the same. I have a 1068. And the usb to 232 converter was the problem as Raphie explained.- Bottom
Originally posted by soundhoundwywong, correct. I suspect our problems were one in the same. I have a 1068. And the usb to 232 converter was the problem as Raphie explained.- Bottom
