Ok my turn to ask for help
I set up a Terk IR repeater the other day so that I can control my Rotel and CD jukebox from the second zone. I installed the receiver in the livingroom and its working fine but I'm having a problem at the other end. What I wanted to do was plug a mono mini plug into the back of the other Terk unit and into the Zone two IR input on the back of the Rotel then run an IR blaster from the IR out to the Sony Jukebox. The problem is it won't control the Rotel at all. I can plug the IR blaster into the Terk and it will control the jukebox from the livingroom but I have yet to get it to work if I plug it into the Rotel. I thought my cable was faulty but last night I plugged it into the power amp trigger and it worked fine triggering the power amp so I think the cable is ok...any suggestions?
